Code - Subaru WRX Forum
post #1 of 8 Old 02-01-2009, 06:41 PM Thread Starter
Code
ok so this is the second time this has happened. I have an 06 wrx with tbe short ram and cobb ap. i keep getting throwing a code and the code is P0244 turbocharger wastegate solenoid "A" range/performance is this bad taht it has happen 2 time within a month and only happens when i get on it.
clipsy is offline
post #2 of 8 Old 02-01-2009, 07:11 PM
Call Cobb,tell them what happened........
dumdum is offline
post #3 of 8 Old 02-01-2009, 07:13 PM
that code means you are overboosting. I know You can get a boost restricter pill to fix the problem, but is your accessport up to date? The maps are made for stock intake so I don't know if the short ram could cause that problem. I used to throw that cod ewhen I would drive on the highway in my 08
ajtoce is offline
post #4 of 8 Old 02-01-2009, 07:37 PM Thread Starter
TY im gonna call them tom hopefully they will help idk if its up to date i bought it over the summer so i will check it tomorrow.
clipsy is offline
post #5 of 8 Old 02-02-2009, 10:36 AM
sounds like your getting boost creep or a boost spike?
is your cruise control light blinking as well?
if it is you can just reset the ecu and avoid WOT.
i think a custom tune would be your best bet.
post #6 of 8 Old 02-02-2009, 10:48 AM Thread Starter
yea it is blinking and check engine light comes on
clipsy is offline
post #7 of 8 Old 02-02-2009, 11:48 AM
yea then your car went into limp mode and it does this to keep it from dangerously overboosting.
You can reset your ecu or just stay out of boost and it will go away in about a day or so.
but to prevent this in the future (or help eliminate it) you need to get a custom tune.
post #8 of 8 Old 02-02-2009, 12:43 PM
isd_intrepid's Avatar
Send a message via Yahoo to isd_intrepid
If you got it last summer. then it is out of date.
cobb support for subaru's
isd_intrepid is offline
