-   -   Code (http://www.wrxtuners.com/forums/f72/code-25210/)
clipsy 02-01-2009 06:41 PM
Code
ok so this is the second time this has happened. I have an 06 wrx with tbe short ram and cobb ap. i keep getting throwing a code and the code is P0244 turbocharger wastegate solenoid "A" range/performance is this bad taht it has happen 2 time within a month and only happens when i get on it.
dumdum 02-01-2009 07:11 PM
Call Cobb,tell them what happened........
ajtoce 02-01-2009 07:13 PM
that code means you are overboosting. I know You can get a boost restricter pill to fix the problem, but is your accessport up to date? The maps are made for stock intake so I don't know if the short ram could cause that problem. I used to throw that cod ewhen I would drive on the highway in my 08
clipsy 02-01-2009 07:37 PM
TY im gonna call them tom hopefully they will help idk if its up to date i bought it over the summer so i will check it tomorrow.
baller_v24 02-02-2009 10:36 AM
sounds like your getting boost creep or a boost spike?
is your cruise control light blinking as well?
if it is you can just reset the ecu and avoid WOT.
i think a custom tune would be your best bet.
clipsy 02-02-2009 10:48 AM
yea it is blinking and check engine light comes on
baller_v24 02-02-2009 11:48 AM
yea then your car went into limp mode and it does this to keep it from dangerously overboosting.
You can reset your ecu or just stay out of boost and it will go away in about a day or so.
but to prevent this in the future (or help eliminate it) you need to get a custom tune.
isd_intrepid 02-02-2009 12:43 PM
If you got it last summer. then it is out of date.
[url=http://www.cobbtuning.com/info/?ID=3260] cobb support for subaru's [/url]
