Old 12-26-2007, 04:00 PM   #1 (permalink)
Reputation: zacwrx07 is an unknown
Clutch smell
I just got my clutch replaced in my rex(don't ask) ha. I have been breaking it in for the 1,000 mile period. I have corrected my known mistakes from before. NO LAUNCHES. No hard shifting. For the first couple hundred miles on the clutch I could smell it. Not bad like after a bad launch but just a little. I figured it was just burning off the new. Well I'm at 1,200 miles now and I can still smell it a little. I was wondering if it was normal that it still smelling like that being that's its still new. Its not strong but I can smell it. Any suggestions or info?
Thanks
Old 12-26-2007, 04:25 PM   #2 (permalink)
Nose Nuggets's Avatar
Reputation: Nose Nuggets is known to be trustworthy and helpful Nose Nuggets is known to be trustworthy and helpful
it usually does not have a constant smell. call the shop you had the work done at and ask if they have had this issue with this clutch in the past.
Old 12-26-2007, 08:02 PM   #3 (permalink)
Reputation: man show is a helpful contributing member
It's sort of hard to diagnose the problem without knowing your driving style. If I had to guess though, I would say you're engaging the clutch way too long when you shift (you should be able to shift smoothly using the clutch for only a second or two each time you shift). I had a friend who had a Saab with over 300,000 miles (that's right, three hundred thousand miles) on it with the original clutch. It is very unusual to have to replace it in the first 1,000 miles. If this is your first vehicle with a manual transmission, just keep practicing and it'll become second nature in no time.
07 WRX - Cobb AP Stage 2
Old 01-04-2008, 11:08 PM   #4 (permalink)
MilesFox's Avatar
Car: 87 RX, 95 Legacy, 88 sedan 4wd conversion
Reputation: MilesFox is an unknown
check to see if the clutch pushrod has been adjusted for the new clutch. i bet its too tight, leaving the clutch partially disengaged at rest.
Old 01-05-2008, 03:13 AM   #5 (permalink)
wrxman420's Avatar
Reputation: wrxman420 is more helpful than not
What clutch did you go with, was it a stock one?
Old 01-06-2008, 08:56 PM   #6 (permalink)
Yeah its the stocker. I just called Exedy and they sent the oem
Old 01-06-2008, 10:24 PM   #7 (permalink)
IH8PVMNT's Avatar
Reputation: IH8PVMNT is an unknown
febreeze
