-   -   clutch engagement / hard to shift (http://www.wrxtuners.com/forums/f72/clutch-engagement-hard-shift-31847/)
WRXParamedic 01-04-2012 04:45 PM
I recently had my clutch replaced on my 05 WRX wagon. As I drove it home I noticed that with the clutch pedal to the floor in 1st (stopped) it starts grabbing and slowly pulling the car forward. I figured that it was due to the friction plate being new and thick. 400 mile into it the problem still exists. Also my car is hard to get into gear when it is stopped or moving, I figured it's because the clutch is partially engaged but also had that prob with stock clutch too. (hard to get into gear) My question is: Can I adjust my clutch pedal to solve the engagement problem and also I have new shifter bushing on order with a short throw shifter. Should that resolve hard shifting issues? Sorry if I'm kicking a dead horse here but I've researched for hours and found bits and pieces but nothing spot on.
RcrsWetDream 01-04-2012 05:32 PM
1 Attachment(s)
Probably just need to adjust the pedal or bleed/adjust the clutch master cylinder. Sounds like even though you have plenty of input from the pedal, the cylinder isn't pushing the fork enough to disengage the clutch.
WRXParamedic 01-04-2012 07:22 PM
I did bleed it last night 4X and did see bubbles come through the clear hose I attached to the valve, although I bled it with the slave still attached to the trans. I'll try adjusting the pedal. Thank you.
WRXParamedic 01-05-2012 01:46 PM
Adjusted the clutch lever 1.5 turns and wow, problem solved. No engagement with pedal to the floor and easier shifts. Thanks.
RcrsWetDream 01-05-2012 03:02 PM
1 Attachment(s)
!Thumbs Up
Good deal. Always nice when it's something simple like that.
johnson9012 09-19-2012 08:38 PM
[quote=WRXParamedic;273990]Adjusted the clutch lever 1.5 turns and wow, problem solved. No engagement with pedal to the floor and easier shifts. Thanks.[/quote]
How did you go about doing this?
[IMG]http://i53.photobucket.com/albums/g62/johnson90512/IMAG0644_zpsb247705f.jpg[/IMG]
[IMG]http://i53.photobucket.com/albums/g62/johnson90512/IMAG0646_zps7f9775ed.jpg[/IMG]
[IMG]http://i53.photobucket.com/albums/g62/johnson90512/IMAG0648_zps94cf6170.jpg[/IMG]
Anyone see where I would do that?
