check engine light, P0244 - Subaru WRX Forum
post #1 of 4 Old 02-04-2010, 06:57 PM Thread Starter
heavy hauler is an unknown
ok, today driving home at 60-65, 5th gear, the car stuttered. blew cel,
2006 wrx, 60,000 miles, perrin drop in air fliter cat back with restrictor removed, cobb stage 1
checked code, the cleared.
any ideas why i would blow a wastegate code?
heavy hauler is offline
post #2 of 4 Old 02-05-2010, 07:29 AM
mfarnham's Avatar
mfarnham is an unknown
You just "over-boosted"; I believe that is the correct term. This has happened to me three times now. It is very common with stage 2, when accelerating hard in 4th and 5th gear. I don't know if it is as common with stage 1, maybe someone else can elaborate. However, you should be fine just clearing the code, and not worrying about it. Is it very cold where you live, cause that could cause this as well? You might need a new waste gate solenoid, but from my experience it is nothing to worry about.
mfarnham is offline
post #3 of 4 Old 02-05-2010, 07:32 AM
mfarnham's Avatar
Also, if you want to make this problem go away for good, you need a good aftermarket boost controller. But that also requires a tune.
mfarnham is offline
post #4 of 4 Old 02-05-2010, 11:51 AM
You can also probably avoid this problem by downshifting into the powerband rather than flooring it at 2400rpms in 5th gear.
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
