Check Engine Code - Subaru WRX Forum
post #1 of 7 Old 05-27-2004, 01:21 PM Thread Starter
LuckyLuch's Avatar
LuckyLuch is an unknown
Angry Check Engine Code
Ok i have had my CEL go on continously for some reason and the dealer does not know why. Here is what they told me last.
"EEC Test and check code P0137. Found rear O2 sensor not switching. check pins and wiring readings at connector to sensor and compare with known good vehicle. reading ok. monitor and found front a/f sensor reading off. contact SOA tech dept with findings and advised of aftermarket air inlet and blow off vavle installed on vehicle. per tech hotline remove and return car back to stock. clear code and return to customer. if light comes back on after parts taken out customer should bring car back to dealer."
All i have in the car is a AEM short ram intake and HKS blow off valve. has anyone else had a problem like this? Any help would be appreciated.... Thanks....
LuckyLuch is offline
post #2 of 7 Old 05-27-2004, 03:20 PM
IBAUCLAPlaya's Avatar
Take off the short ram and the BOV and see what happens. If it is still on, its the dealers problem, sounds maybe like a bad O2 sensor. If it goes off then it is probably something w/ the intake.
IBAUCLAPlaya is offline
post #3 of 7 Old 05-27-2004, 03:40 PM
Cosmo's Avatar
Images: 15
That code would have nothing to do with the intake or BOV. Take it to the dealer.
Cosmo is offline
post #4 of 7 Old 05-27-2004, 06:38 PM
I still wouldn't have taken it to the dealer w/ any mods done that can be easily removed like those.
post #5 of 7 Old 05-27-2004, 08:19 PM
Replace the O2 sensor!! I had my CEL come on after no more than 3 weeks of having my car (no mods). Took it in and they found that the rear O2 sensor was bad. They told me that Subaru must have had a bad batch because they've had to replace a few of those on the new Subarus. Good Luck, hopefully that's the problem... or else I Really wish you good luck.
post #6 of 7 Old 06-05-2004, 08:16 PM
WRXeffects is an unknown
LuckyLuch, just wondering if you have had any turbo flutter after installing your intake? Not trying to take over forum; just a question.
WRXeffects is offline
post #7 of 7 Old 06-06-2004, 02:18 AM Thread Starter
LuckyLuch's Avatar
I actually have not had any problems since i got the car back. Maybe they actually replaced the sensor this time... What do you mean by turbo flutter?
