I have a 02 WRX and that damn light just won't go out!!! I have tightened the gas cap way past 30 clicks and the light still won't go out...Any ideas?!?!?
Sorry for the delay guys...I had to get the car checked out.
The codes that the garage gave me were P0-462 and P0-457.
The 462 one is Feul level sens circuit low volt .
457 is Evaporative emission control system leak detected...
Can anyone explain this to me in english please?!?!?
Yes it does. The WRX has a sensor to make sure the fuel tank is pressurized (i.e. doesn't leak or have holes). Since you fill up with the car running the sensor stays on and detects that as a leak in the system. Turn the car off before refueling and CEL will go away after a while and this won't happen anymore.
try what mike wrx told you to ,after diconecting the negative cable from the batery and waitnig for 10sec then conect it back this should turn your eng light off what this do is clears the codes
