Cel po180 - Subaru WRX Forum
post #1 of 4 Old 07-25-2008, 09:45 AM Thread Starter
robelia1 is an unknown
Cel po180
I upgraded my 06wrx to a vf39 with all supporting mods, tbe, cobb, ic, fuel pump. Leave the mechanic, burning all the spilled coolant, but a CEL was on and cruise light flashing. Its cel po180 fuel temperature, circuit A sensor. What do you think this could be? My mechanic used all the stock stuff for the walbro pump, he says it fits fine and you dont need any of the wiring provided by walbro. Is this car performing the way it should, or should i expect more power once this cel is taken care of?
robelia1 is offline
post #2 of 4 Old 07-25-2008, 12:17 PM
sfelix818 is more helpful than not
Ive had a similar problem like that but somebody told me reset the battery and tighten up the gas cap. It worked so now everytime I fill up I give the gas cap about 8 clicks to make sure the oring seats.
Dont know if this would help you.
sfelix818 is offline
post #3 of 4 Old 07-25-2008, 12:31 PM
Longshot's Avatar
It's either that or take it back to the mechanic as it's obviously related to the fuel system which he just worked on.
DTRacing Tuned
Longshot is offline
post #4 of 4 Old 07-25-2008, 02:50 PM Thread Starter
Sorry its PO183 CHECK ENGINE LIGHT, I just reset the battery now. Still dont feel like im getting the peak boost. While the CEL was on my cobb said i was running 10lbs psi. This map should be at 16.6. Reset the battery now, wait it out a few runs before I can determine a difference, but im assuming it would be way obvious right?
robelia1 is offline
