cel p1507 ? - Subaru WRX Forum
post #1 of 9 Old 09-11-2005, 06:16 PM Thread Starter
browning 02 is an unknown
cel p1507 ?
my 02 wrx is runing like crap has anybody ever had cel p1507 ?
browning 02 is offline
post #2 of 9 Old 09-11-2005, 08:36 PM
Look at the very first sticky thread on the Problem Dianosis page. The OBDII key for our cars is there.
P1507 Idle Control System Malfunction (Fail Safe)
Sounds like your car is in safemode. Reset your ECU by disconnecting the battery and draining any remaning charge by pushing on the brakes. See if that fixes it. My question would be what did you do to cause it to go into safemode.
post #3 of 9 Old 09-12-2005, 08:33 PM Thread Starter
thanks for helping, but i tried to reset the ecu whith my scanner and by the battery.
after that i start the car and it idles high then cel p1507 comes up?
also i looked at the code list thread first.
post #4 of 9 Old 09-12-2005, 08:45 PM
BlueDemon's Avatar
BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
Check all engine grounds from the battery. Make sure you have no loose grounds. This CAN cause abnormal idling and thrown codes.
Blue
BlueDemon is offline
post #5 of 9 Old 09-12-2005, 09:00 PM Thread Starter
thanks, i will check later and tell you what i find?
post #6 of 9 Old 09-13-2005, 11:04 AM
hondaeater is more helpful than not
sounds like an IAC issue (Idle air control). This allows air to pass when the throttle butterfly is closed to maintain idling conditions. It sits atop the TB. Check your throttle cables to make sure they are moving freely and not getting caught when returning to idle position, if they are fine, you can remove and clean the IAC with TB cleaner, but that's probably just a short term fix, probably need a new one.
At least clean and see if the problem goes away, then you'll know that's the prob.
hondaeater is offline
post #7 of 9 Old 09-14-2005, 08:33 PM Thread Starter
thanks thats what i thought.
post #8 of 9 Old 09-15-2005, 02:08 PM
stumbled across this today
http://forums.nasioc.com/forums/showthread.php?t=781242
here's another technique, this one looks easier
http://endwrench.com/images/pdfs/ISCSpring04.pdf
post #9 of 9 Old 09-17-2005, 08:06 PM Thread Starter
thanks, i tryed cleaning iac with cleaner got the same results.
the web site was helpful, my code scanner reads (speed control malf. aux input)
