Old 03-12-2008, 12:03 PM   #16 (permalink)
Car: 04 WRX
Put it on Map 0 and tell me if it still does it, does it less, or more.
RIP Colin McRae
Old 03-12-2008, 08:04 PM   #17 (permalink)
What octane gas you using?
Aarg matey!
ECU Pirated by RomRaider
Old 03-14-2008, 10:42 AM   #18 (permalink)
KillerRabbit's Avatar
Car: 04 WRX
Reputation: KillerRabbit is an unknown
93 octane with NOS octane booster( says it changes it by 6 octane numbers), havent had time to switch maps, ill keep you posted Vew
Old 03-14-2008, 11:04 AM   #19 (permalink)
Car: 04 WRX
That stuff is a waste of money. When it says 6 points, you just increased your octane from 93 to 93.6, NOT 99.
RIP Colin McRae
Old 03-14-2008, 02:39 PM   #20 (permalink)
Car: 04 WRX
it says 60 points or 6 octane numbers, just telling you what it says bud
your prob right but thats what is says on the side of the box
Old 03-14-2008, 06:38 PM   #21 (permalink)
Reputation: baller_v24 is a helpful contributing member
Originally Posted by KillerRabbit View Post
alright guys, here is some bad news
took out the plugs and they are stock bkr6eix replacement iridium plugs
it still flashes after replacement
help me out
those are one step colder plugs u replaced them with right?
and were the plugs fouled pretty bad?
did u try disconnecting battery, and pumping the brakes to reset the ecu also?
talk to a tuner, see what they can do for u.
Old 03-14-2008, 08:39 PM   #22 (permalink)
Try doing a boost leak test and cleaning the MAF.Have you ever changed the front O2 sensor?
Aarg matey!
Old 03-16-2008, 11:30 PM   #23 (permalink)
Car: 04 WRX
yes i did replace it with bkr7iex or one step colder plugs, after i put those in changed my oil to royal purple and reset the ecu.
i have not replaced the front o2 sensor but am really close to doing it.
i havent cleaned the maf sensor either
it is due for a timing belt change, and i think it might of jumped time a tooth or something like that because its worn out.
im replacing it with a greddy timing belt, this wed
ill keep you posted , and let you know more wed
Old 03-16-2008, 11:47 PM   #24 (permalink)
u said u just bought it and it's doing all these things?? i think the first thing u need to do is to get a tune. go to a reputable tune shop and they could probably fix all the frankenstein work the person before u did too it.
Old 03-17-2008, 02:44 PM   #25 (permalink)
Car: 04 WRX
too far for a good tune, got to make it work
Old 03-17-2008, 03:19 PM   #26 (permalink)
http://us.st11.yimg.com/us.st.yimg.c...91_3394732.jpg
says 7 points (.7 octane) in 16 gallons. The do make some other types with different numbers but 60? I am not calling you a liar, I'm saying if you saw 60 on the bottle, you don't read very well.
Octane Boosters Testing - Tech Review - European Car Magazine
Here's a great link where they did some real analysis of these products. Short answer: They're not worth the money.
By their analysis, the MMT based formula in the NOS stuff is roughly 215 octane. To hit 60 points of gain on 16 gallons of 93 octane from a 12 oz addititve, you'd be looking at mixing in 1125 octane. You do realize how stupid that makes you sound? EDIT: BTW this stuff destroys catalytic converters and is illegal.
Engineers can't spell, sorry!
Old 03-20-2008, 02:44 PM   #27 (permalink)
Car: 04 WRX
alright guys, sorry its taken so long to get back to you, to start i changed maps to 0.
same thing happens just lost in power because of the map change.
i decided to do a boost leak test as you guys advised and i found the intercooler piping to intake is leaking, i hooked a smoke machine up to it and it leaked there.
is that one reason , or could it be the car jumped time?
it is due and wed i was going to do it, but due to some parts im waiting to do it tue
let me know what you guys think, Thanks Aaron
Old 03-20-2008, 08:31 PM   #28 (permalink)
02wrxnfx's Avatar
Reputation: 02wrxnfx is an unknown
too far? if your that concerd about your car, you should make the trip. stay away from street races. those are for hondas
Old 03-20-2008, 10:09 PM   #29 (permalink)
Car: 04 WRX
Let me rephrase that: I'm not too far from a good tune, the car was running fine before this thing happened. It didn't need a tune at the time. I'll be more then happy to make the trip for a tune, but it's not needed right now for a daily driver.
The NOS octane booster, if you read on the side, pulls it up 60 points, or in parenthesis 6 octane numbers. Don't talk smack if you don't know what you are talking about.
The picture is of the same stuff I am using. Before you start insulting me, read the side of the box and then let me know what you think.
Well, other then the fact that I need a good tune, what is the problem with the knocking?
The intercooler charge pipe hose has a leak. Could that be what is causing the problem?
I just need some information and I would really appreciate it if you guys could share.
(Girlfriend typed that, lol)
Thanks, Aaron
Old 03-24-2008, 07:14 AM   #30 (permalink)
VD5505's Avatar
Reputation: VD5505 is more helpful than not
so did you ever find out what was wrong with your car???
For adver
