Old 05-30-2008, 02:12 PM   #61 (permalink)
Longshot's Avatar
Car: 05 WRX
Originally Posted by KillerRabbit View Post
alright gents, got the utec off or on 0 and it runs down the road fine, the only prob i can think of it tune,
im also throwing cel for crnk sensor
and knock sensor
let me know
Light that sucker on fire and file an insurance claim
DTRacing Tuned
Old 05-30-2008, 03:26 PM   #62 (permalink)
^^^^HAHA... Change the crank and knock sensors then.
Old 05-30-2008, 06:24 PM   #63 (permalink)
and knock sensor
let me know
Let you know what?Take the frigg'n car to a mechanic/tuner.If you can't afford it then sell the car.You gotta pay to play with hotrods and if you don't know the first thing about fixing them yourself them yourself,your gonna need deep pockets.Not trying to be a donkey but you should have just bought a stock WRX and stuck with that.If you bought it modded you have just inherited someone elses problems.All these people responding give you advise and you don't take it/use it.?Why bother continuing to ask questions.....
Aarg matey!
ECU Pirated by RomRaider
Old 05-30-2008, 07:37 PM   #64 (permalink)
KillerRabbit's Avatar
Car: 04 WRX
Reputation: KillerRabbit is an unknown
im sorry i dont listen to you guys, ive been on forums before and you have no idea how many people are wrong. its not that i dont want to take or use the advice, i just would like to get a good idea of wats wrong and evaluate it from my pov.
i ordered my knock and crank sensor today.
now can someone tell me what the crank sensor does, it controls ignition and timing right?
Old 05-30-2008, 08:37 PM   #65 (permalink)
Yes,the crank sensor has to do with timing.Considering you still had problems before the DTC/CEL showed up for the crank and cam sensors, I'm guessing you still have other issues going on.The easiest way to deal with this car without going to a mechanic is to purchase a Tactrix cable (if you have a laptop) and datalog the car.Romraider has a free logger you can use and see data in realtime along with logging.For some reason I see you buying alot of parts that end up possibly not solving your problems.Have you tried reseting the ECU after getting the codes?Both the crank and cam sensors are inductive magnetic pickups.I would have pulled them and cleaned them, then reset the ECU before buying new ones.
Aarg matey!
Old 05-31-2008, 12:23 AM   #66 (permalink)
Car: 04 WRX
Yes i did reset my ecu, and I did take out the crank sensor and clean it. Code still comes back. Sprayed off the connectors as well.
Old 05-31-2008, 02:05 AM   #67 (permalink)
Reputation: baller_v24 is a helpful contributing member
just because the sensors through a CEL light does not mean it needs a new sensor. it probably means it's doing it's job. +1 on datalogging or like ive said before, and ill say it again, get a tune and consider it done.
Old 05-31-2008, 08:36 AM   #68 (permalink)
It might be possible these DTC/CEL's have something to do with the newly installed timing belt.Maybe it's off a couple teeth.
Aarg matey!
Old 05-31-2008, 12:04 PM   #69 (permalink)
^^^^^word
