cel fix advice - Subaru WRX Forum
post #1 of 7 Old 03-18-2010, 05:29 PM Thread Starter
goodboyWRX's Avatar
goodboyWRX is an unknown
cel fix advice
Every now and then my car refuses to start. No cranking, no noise, nothing. I keep trying and it eventually starts and throws a code for crankshaft position sensor malfunction. Now the cel is stuck on and its also throwing a code for heat 1 bank 1 whatever. Front o2 sensor is shot. I was planning on replacing my stock uppipe anyway so I was thinking I would buy a catless one without an o2 bung and do the resistor mod. I don't know if the crankshaft position sensor led to the o2 failure but recently I've been getting atrocious gas mileage, like it used a half of a tank to go about 60 miles. Anyone ever have a similar problem? Thanks.
goodboyWRX is offline
post #2 of 7 Old 03-19-2010, 08:15 AM
Did you try cleaning your MAF sensor? Check your air filter? Spark plugs? Left unattended, those can also lead to poor gas mileage.
post #3 of 7 Old 03-19-2010, 08:29 AM
Also could be a bad O2 sensor telling the ecu your car has no air left and has it dump fuel to compensate... Change out the sensor and see if that helps.
post #4 of 7 Old 03-19-2010, 10:11 AM Thread Starter
goodboyWRX's Avatar
replacing the o2 sensor this weekend hopefully. will definitely check/clean the intake system and plugs.
post #5 of 7 Old 03-19-2010, 06:52 PM
sivart08 is an unknown
i have almost the same problems... my car wont start sometimes.. does the same thing.. and i have a check engine light. auto zone said it was the o2 sensor.. i need to get one too.. do you have any problems with jerky driving???
sivart08 is offline
post #6 of 7 Old 03-19-2010, 08:36 PM
slvr04wrx is an unknown
when my o2 sensor went three or four months ago my gas milage was horrible, and randomly would start bucking throughout my drive.
slvr04wrx is offline
post #7 of 7 Old 03-21-2010, 09:15 AM
Might be a dumb question, but how long do O2 sensors normally last on WRX/STis - stock, partially, and/or fully modded? How many miles do you guys have on your cars?
