11-29-2012, 06:23 PM
#1 (permalink)
CEL on after removing and reinstalling stock intake
I was doing a little cleaning up/maintenance under the hood, and pulled off the (stock) intake to make some access a bit easier. In the interest of not damaging the Mass Airflow Sensor, I removed it from the intake, disconnected it from the harness, and set it on my console while I was tinkering around.
I put everything back together, MAF sensor on the correct way (facing the front), reconnected the ground on my battery, started the car, and after about 5 seconds the CEL came on.
I did the quick reset (disconnect negative, hold brake pedal, reconnect), same issue. No light initially, then comes on after a few seconds of idle.
I have not had the code pulled yet, planning on doing it this weekend if any info/suggestions don't cure the problem.
Any ideas?
Edit - Car runs fine, nothing seems noticeably different from before the CEL came on.
