-   -   CEL on after removing and reinstalling stock intake (http://www.wrxtuners.com/forums/f72/cel-after-removing-reinstalling-stock-intake-33333/)
HAMMATRON 11-29-2012 06:23 PM
I was doing a little cleaning up/maintenance under the hood, and pulled off the (stock) intake to make some access a bit easier. In the interest of not damaging the Mass Airflow Sensor, I removed it from the intake, disconnected it from the harness, and set it on my console while I was tinkering around.
I put everything back together, MAF sensor on the correct way (facing the front), reconnected the ground on my battery, started the car, and after about 5 seconds the CEL came on.
I did the quick reset (disconnect negative, hold brake pedal, reconnect), same issue. No light initially, then comes on after a few seconds of idle.
I have not had the code pulled yet, planning on doing it this weekend if any info/suggestions don't cure the problem.
Any ideas?
Edit - Car runs fine, nothing seems noticeably different from before the CEL came on.
06_hawk_eye 11-29-2012 07:06 PM
Did you pull the code?
[color=gray]Sent from my iPhone using [url=http://www.autoguide.com/mobile]AutoGuide.com App[/url][/color]
HAMMATRON 11-30-2012 10:33 AM
It's on the agenda for the weekend, haven't had time to make it down to O'reilly's yet
justinwursten 11-30-2012 12:26 PM
My guess is you didn't attach something right or maybe you accidentally did do something to the maf sensor D:
I suggest getting the code pulled first. And if you don't. Carefully take it apart and put it together again haha. Good luck!
