car will not boost past about 5psi and boggy around 3500rpm - Page 2 - Subaru WRX Forum
post #16 of 25 Old 03-01-2012, 08:58 PM
Shame on you. $8 Randy
$8
OP----------> Pro-Kit: SUBARU WRX STI (2004+)
haha.....problem solved now, Im like a kid at times. I couldn't wait..lol
post #17 of 25 Old 03-01-2012, 08:59 PM
What BPV/BOV are you running?
Can you smell fuel?
post #18 of 25 Old 03-02-2012, 07:28 PM Thread Starter
21latemodel21's Avatar
21latemodel21 is an unknown
i figured it out i was looking around and notice some loose wires on the mass air flow sensor so i unplugged it to put it in to limp mode and it runs like a champ.
21latemodel21 is offline
post #19 of 25 Old 03-02-2012, 09:44 PM
Something in that statement isn't right. Limp mode runs like sh!t....not like a champ. Were you in limp mode until you plugged it back in?
post #20 of 25 Old 03-03-2012, 09:38 AM Thread Starter
limp mode you still have full power. just you get reallly shitty fuel milage. i ordered the sensor itll be here monday. hope everything thing stays good!
post #21 of 25 Old 03-05-2012, 06:05 AM
^No, limp mode is not just cruddy mileage.
Here's a decent description:
Your engine management and maybe even your transmission is controlled by the ECU. As you know, all computers crash, all software has bugs, and mechanical equipment fails. As such, many ECU units are fitted with a 'limp home mode'. When it detects that something semi-serious is wrong, it enters the limp mode, which means that the engine won't rev beyond a pre-programmed speed, you can't accelerate very fast, or you may indeed be speed-restricted to 40 mph or similar. The transmission may even stay in one or two gears. Bad? Well, no, not really: The alternative would be to either let you drive at regular speeds, with the danger of letting you trash your car (expensive repair, means happy repair people, but angry driver), or stopping you from going anywhere (expensive recovery and stranded on the side of the road means happy recovery company, but angry driver).
post #22 of 25 Old 03-09-2012, 04:52 PM Thread Starter
i dont know what i should do. i ordered a aftermarket mass air flow sensor that didnt work. ordered a subaru sensor that didnt work. for some reason the harness that connects to the mass air flow sensor two wire where flipped around from the spec sheet. and its still acting up. then when its unplugged it has more power but starts leaning out around 5000rpm. and horrible fuel mpg i mean 40 miles sucks away a quarter tank. is it possible that when i disconnected the battery that i lost my tune? and i cant find anyone in southern wi that is subaru performance that does tuning or anything. what do you guys do for tunes? did you download your own? my car has the two wires that plug into a laptop. also monday we were going to check the air flow and fuel pump and everything. hes got a smoke machine for the air to see if its leaking anywhere. i need to find someone thats good with these cars in my area!$$$
post #23 of 25 Old 03-12-2012, 05:45 AM
How far are you from Illinois?
You "shouldn't" have lost your tune unless the car was realtime flashed and not "flashed" correctly.
So you don't have an AP... just the tactrix cable and laptop?
post #24 of 25 Old 03-12-2012, 09:48 PM Thread Starter
yeah two wires for a lap top down by the foot pedals. and im about 45 minutes from rockford il
post #25 of 25 Old 03-13-2012, 06:00 AM
2 wires from the foot well on the inside?
Is it a UTEC Delta ?
Standalone/piggyback
