car will not boost past about 5psi and boggy around 3500rpm - Subaru WRX Forum
post #1 of 25 Old 02-29-2012, 06:31 PM Thread Starter
21latemodel21's Avatar
i just bought this car yesterday and went about 500 miles no problems at all. Then today i went to get on it and it sounds like the rev limiter hits at about 3500rpm this happens in 1st gear around 4500rpm. i cant get alot of boost out of it either 4 to 6 pounds max. on the way home when it had no problems it was around 18 psi. i think its a coil or plug i dont know probably something electrical. No check engine light came on either. let me know what you think. THANKS
21latemodel21 is offline
post #2 of 25 Old 02-29-2012, 06:49 PM
How many miles on it? If you just bought it I would take it right back to where it was purchased and demand its fixed. Unless you were beating the crap out of, nothing should be remotely wrong with the car.
post #3 of 25 Old 02-29-2012, 06:55 PM Thread Starter
73000 miles bought it kind of long distance from private seller he took extremly good car of the car. and yeah its a new car to me i beat the hell outta it just accelerating fast. also notice on my way home cruising around 80mph hit the gas and it make that noise like when the waste gate hits but makes the noise 3 times. i cant think of what thats called... the checheche noise lol
post #4 of 25 Old 02-29-2012, 08:05 PM
Did it just lose all of its boost the next time you turned it on? Or on the way home?
post #5 of 25 Old 02-29-2012, 08:06 PM
bad grocerygetter's Avatar
Most likely compressor surge is that noise. What kind of mods are done to the car so we may have a place to start helping you. Sounds like maybe the car went to limp mode but with no cel its hard to say.
Kevin.
bad grocerygetter is offline
post #6 of 25 Old 02-29-2012, 08:11 PM
I lost my boost twice now since owning mine a little over a year now.
Both times it was due to hitting high psi and blowing my make shift BPV gasket.
post #7 of 25 Old 02-29-2012, 08:35 PM Thread Starter
Bc fully adj suspension, Full Invidia g200 exhaust, Invidia bell mouth down pipe, 38mm tial external wastegate,tial bov, turbo xs fmic, aem intake, 255 walbro fuel pump, ngk one step colder plugs,kart boy short throw shifter, aem tru boost gauge, aem wideband a/f gauge,cusco oil catch can, protuned at 18psi, hks turbo timer etc. it just wont boost at all it seems like it takes foreverrrrr to get up to speed compared to what it was like for the short time i had it lol
post #8 of 25 Old 02-29-2012, 08:39 PM Thread Starter
ok ill explain it best i can.. i take off in first 4500rpm it sounds like i hit the rev chip. 2nd gear 3500 rpm rev chip. same until 6th its a turbo hiss and then if i hit the gas a little further is hits the wastegate. and after i was already home from my trip i went to drop my buddy off and it was fine then right when i got to my road all of a sudden it was doing this
post #9 of 25 Old 02-29-2012, 08:43 PM
Sounds like a nice Mod list. Is it on the stock turbo still?
Did you do a hard pull to show off to your friend? Sounds like a possible boost leak.
post #10 of 25 Old 02-29-2012, 08:44 PM
Honestly I would go over the entire engine bay and make sure no couplers have come off. Check the fmic couplers and anything to do with the boost system...as far as hoses go. Sounds like you have a big boost leak. Or a tuning issue...sorry bud sounds like you may have a tough one to figure out
Kevin.
post #11 of 25 Old 02-29-2012, 08:49 PM Thread Starter
hell yeah i pounded on the car! and i had it up on the hoist at work today and i noticed by the intercooler where the rubber hose connects there was a small crack in it. but it didnt look like it was all the way through. but that much boost would probably open it up? possibly
post #12 of 25 Old 02-29-2012, 08:56 PM
Could be the whole way through.
post #13 of 25 Old 02-29-2012, 09:00 PM Thread Starter
its far up though like right before the clamp so its on the metal where hose connects its not in the middle. but even if it was leaking boost would i lose that much power and have a missing sounds still? thats why i thought it may be a coil or maybe plugs? the cars fueling runs really rich and may be fouling out the plugs.
post #14 of 25 Old 03-01-2012, 05:51 AM
Shame on you. $8 Randy
$8
OP----------> http://www.turboboostleaktesters.com...WRX-STI/Detail
post #15 of 25 Old 03-01-2012, 06:02 PM Thread Starter
ill try that.. i dont think its a boost leak though it sounds electrical like a coil went bad maybe. or a plug could of the car runs really rich i think it might be easy to foul a plug
