Car sputtering/cutting out under throttle...? - Subaru WRX Forum
post #1 of 21 Old 02-24-2012, 12:45 PM Thread Starter
gangster is an unknown
I have an 03 wrx w/ 170,000 miles on it. I replaced the stock wore out motor w/ a fresher 02 motor. The motor has about 100,000 miles on it now. I have upgraded my exhaust to an all catless system....down pipe, up pipe all the way back out. It has a stage 2 tune as well.
Well last week coming home from a fishing trip my car started actin like a bitch! Under throttle much more than half it will sputter out....kinda like its not getting enough fuel. SO i put some fuel systems cleaner in my tank w/ a full tank of gas. Its about half empty now and the problem has gotten a little better. But what do you guys/girls think i should do now? Have you had similar issues?
I would like to upgrade my injectors...just not now $$$. I also have a new walboro fuel pump but havent installed it cause i want to do injectors at the same time. Thanks in advance
gangster is offline
post #2 of 21 Old 02-24-2012, 12:55 PM
Might just be a bad tank of gas. Keep topping it off with the pee-water you call premium when you can. Pick up a few bottles of B12 Chemtool (po-man's seafoam).
post #3 of 21 Old 02-24-2012, 02:53 PM Thread Starter
does the b12 chemtool go into the gas tank?
Our CA gas is spendy and garbage....it sucks
gangster is offline
post #4 of 21 Old 02-24-2012, 03:26 PM
Yes it does. 1oz per gallon.
post #5 of 21 Old 02-24-2012, 03:49 PM
Why are you talking about further modding a car (completely pointless mods on top of that) when you have problem you haven't even diagnosed yet?
post #6 of 21 Old 02-24-2012, 05:31 PM
wagonracer's Avatar
Any CEL codes ?
Cullen
wagonracer is offline
post #7 of 21 Old 02-24-2012, 05:35 PM
Fuel filter, replace it and see what happens.
post #8 of 21 Old 02-25-2012, 09:49 AM Thread Starter
IF my injectors were part of the problem i was going to upgrade them.
WHy do you respond and give me a stupid answer that doesnt answer any ?'s
gangster is offline
post #9 of 21 Old 02-25-2012, 09:51 AM Thread Starter
Originally Posted by wagonracer View Post
Any CEL codes ?
No CEL.....How ever i did have the cel flashing at me for about 5 sec while this happened one of the times. Then went back to no cel...it didnt stick around at all....just flashed.
gangster is offline
post #10 of 21 Old 02-25-2012, 10:32 AM
Why do you give a stupid response when nothing in your original post said that was the case.
It's not the injectors. There are 2 dozen things that will causes this before your injectors fail.
post #11 of 21 Old 02-25-2012, 02:40 PM
Alrighty then.... REPLACE THE FUEL FILTER!!!!
post #12 of 21 Old 02-27-2012, 06:54 AM
He has 2 right?
Try the 1 up front FIRST as Keith suggested.
post #13 of 21 Old 03-01-2012, 09:34 PM Thread Starter
I replaced my fuel filter....still bogging/hesitating.
gangster is offline
post #14 of 21 Old 03-02-2012, 06:51 AM
^The one up front only?
post #15 of 21 Old 03-02-2012, 09:47 AM Thread Starter
^^^yes....in an 03 do i have one in the tank above the pump as well?
gangster is offline
