car failed inspection automaticly for CEL on.. - Page 2 - Subaru WRX Forum
post #16 of 29 Old 12-14-2008, 12:04 AM
blk02wrx is an unknown
Send a message via AIM to blk02wrx
Originally Posted by 03 CrazyTaxi View Post
Another tuning option is ROMraider, it's basically free. Just get a $75 tactrix cable and a laptop. You'll need to get ECU Flash, it's free. I have a stage 2 tune for the 03 I can send to you. It'll get you to pass but you need to get an actual tune.
not to steal the thread but were do you get a tetrix cable for $75? i could only find them for like $169!
O2 PEARL BLACK WAGON with some modds
blk02wrx is offline
post #17 of 29 Old 12-14-2008, 12:43 AM
03 CrazyTaxi's Avatar
P0122 - Throttle position sensor A Low Input
P0171 - System too lean
P0507 - Idle control RPM higher than expected
P0457 - Evap leak detected (fuel cap)
P0420 - Cat efficiency below threshold
P0519 - Idle control malfunction (fail-safe)
Dude, you got some serious issues. The ones I've put in bold are the ones that really worry me. Sounds like you may have bought a lemon or whoever did the work seriously messed your car up.
03 CrazyTaxi is offline
post #18 of 29 Old 12-14-2008, 01:03 AM Thread Starter
413TreX is an unknown
so im lookin at some expensive problems or what??
413TreX is offline
post #19 of 29 Old 12-14-2008, 01:43 AM
Hard to say without actually looking at the car. Sounds like you have a bad TPS, check your gas cap and need a good tune.
post #20 of 29 Old 12-15-2008, 09:40 AM
isd_intrepid's Avatar
isd_intrepid is an unknown
Send a message via Yahoo to isd_intrepid
sounds like the car is setup for something it doesn't have.
isd_intrepid is offline
post #21 of 29 Old 05-31-2009, 10:39 AM Thread Starter
access port stage 2 tune - codes pulled
ok so i got a tune flashed ecu to stage 2 91 octane, cel never shut off, p0031 heater control circuit low bank 1 sencer 1... p0113 intake temp circuit high input.. how do i fix this only mods are tbe, perrin inlet tube , perrin crank pulley and everything else is back to stock ie, intake and bov
413TreX is offline
post #22 of 29 Old 05-31-2009, 12:43 PM
P0113 - clean the MAF with some MAF cleaner or CRC QD Electrical cleaner.
P0031 - Replace the front O2 sensor.
After that, reset the ecu by pulling the negative off the battery and step on the brake for 5 seconds.
post #23 of 29 Old 05-31-2009, 09:03 PM Thread Starter
brain fart , where is that located? lol
413TreX is offline
post #24 of 29 Old 05-31-2009, 09:39 PM
I'm pretty sure its the exhaust manifold on the passenger side
post #25 of 29 Old 06-01-2009, 08:13 PM
pb-king07's Avatar
pb-king07 is an unknown
How did the car run with all the CELs going off??
pb-king07 is offline
post #26 of 29 Old 06-01-2009, 09:34 PM Thread Starter
actually ran pretty fine, all besides the rough idle and occasional misfire here an there but other than that alright i guess ... now that i reprogramed the ecu with stage 2, its way faster from mid to high rpms. i cleaned the MAF sensor and that code is gone, the only thing that i need is the front o2 sensor an i hope to have no CEl on and pass inspection
EdIT: today i did a "dyno" pull on the AP and i only got 265.4 hp and i only hit 8.3lbs boost does that sound right or is there another problem????
413TreX is offline
post #27 of 29 Old 06-16-2009, 05:51 PM Thread Starter
finally got it to pass with your peoples help thanks to all! ps. MA inspection is pretty tough to pass an i passed with tbe and stage 2 AP !
413TreX is offline
post #28 of 29 Old 06-16-2009, 06:59 PM
congrats man
post #29 of 29 Old 06-16-2009, 07:59 PM
Congrats on that man.
