Car acting up - Subaru WRX Forum
post #1 of 5 Old 04-18-2011, 05:33 PM Thread Starter
lancer_013's Avatar
lancer_013 is an unknown
Car acting up
Well I have an 02 wrx which may of have had a cobb tune I disconnect the battery and installed a turboxs utech but was running the bypass when I went to start it it didn't sound good so I took it out and re put the stock one now the ar is bogging and feels like theres no power won't rev pass 4500 rpm
lancer_013 is offline
post #2 of 5 Old 04-18-2011, 06:10 PM
baumgartenb's Avatar
baumgartenb is an unknown
sounds like a boost leak, how is the bpv gasket? And did you hook up the recirculation hose up correctly?
Brian
2002 stage 2 WRX - DD
1993 Trans Am - summer car
baumgartenb is offline
post #3 of 5 Old 04-18-2011, 11:07 PM Thread Starter
lancer_013's Avatar
yeah the car goes up and down thew idle whats the bpv gasket also i did touch nottin in the engine
post #4 of 5 Old 04-19-2011, 09:11 AM
bad grocerygetter's Avatar
Bpv gasket is the gasket on the bypass valve. You want a good seal there that can be a major boost leak if its not sealed properly.
Kevin.
bad grocerygetter is offline
post #5 of 5 Old 04-22-2011, 10:17 AM Thread Starter
lancer_013's Avatar
Thank u found out it was my maf
