-   -   cant get full boost (http://www.wrxtuners.com/forums/f72/cant-get-full-boost-32385/)
btsplat 04-18-2012 05:58 PM
cant get full boost
i have a stock 02 wrx with 112k can only get about .5 boost on the gauge. sometime it will kick in and give me full boost. i put 12v to the soleniod and you can hear it click
pzr2874 04-19-2012 05:53 AM
So you're getting ~9-10 lbs?
Check for a boost leak. Mainly under the TMIC and TB coupler (those bandclamps suck). If you find they are crap, pick up some worm clamps.
Have you done a smoke test before? Do you have a pressure tester to check for leaks as well ?
bad grocerygetter 04-19-2012 07:07 AM
Is it happening in any gear or specific ones. I don't see more than 10 or so in first but 3-5 I hit full boost.
dustin10 08-02-2012 08:57 PM
whats MPa ratio for turbo psi? Im getting only .04-feel like I used to get near .09 on the boost gauge quite often or even .1 dont remember exactly. im having it tuned and full stage 2 put on wednesday aug 8th, I dont want to cancel because getting it to fit my work schedule is so tough and i have all the beautiful parts staring at me in my apartment :) I just got a code for P1443, could this have anything to do with low boost now? Im also checking 3rd gear to see if its just in gears 1 and 2 because thats all i checked today. the P1443 hasnt popped again since that one time... my car is an 02 wrx, also had a sound system put in, could any electronic piece have anything to do with boost haha probably not but just giving all info as to let you know about my situation. im having a valve gasket oil leak fixed this monday at a dealership, could this have anything to do with my situation?
pzr2874 08-03-2012 06:22 AM
dustin, can you add punctuation to that paragraph? hahaha
If someone installed a system in the car and it was fine b4 the install..... Then there is your culprit.
dustin10 08-03-2012 08:48 AM
[quote=pzr2874;283493]dustin, can you add punctuation to that paragraph? hahaha
If someone installed a system in the car and it was fine b4 the install..... Then there is your culprit.[/quote]
Thanks for the response, all the help is welcomed! A little punctuation can be done haha. A sound/audio system sub/components/electrical could affect boost levels? Isn't .04 low or is that normal? Also I havent WOT until before the code popped also, so I'm wondering if there could be some interaction there...could any particular hoses be responsible? I know all of this is hard to gauge being that the car isn't in front of you but any ideas are awesome and I appreciate it. I'm getting a new solenoid boost controller when i get my car tuned, I wonder if this would help. But I really dont want to get full turboback, upipe, and tune done it if i cant even make stock boost...
also update, wot in 3rd couldn't get boost higher than .04 again :(
pzr2874 08-03-2012 10:20 AM
Are you reading boost off the Lamco gauge in your car?
dustin10 08-03-2012 08:34 PM
[quote=pzr2874;283505]Are you reading boost off the Lamco gauge in your car?[/quote]
Yeah if the lamco is the stock boost guage then yeah
pzr2874 08-03-2012 10:05 PM
So no AP or any other way to measure boost?
Just a boost leak somewhere
dustin10 08-04-2012 10:04 AM
[quote=pzr2874;283527]So no AP or any other way to measure boost?
Just a boost leak somewhere[/quote]
yeah i think i will try and take it to a place up here to check where you said with the bandclamps and maybe do a smoke test if they have the equipment. thanks for the ideas, i know its hard to give much advice when your not even in front of the car but i appreciate it lol of course this happens right before i find some time to get it tuned, oh well one thing at a time i guess.
pzr2874 08-04-2012 01:56 PM
Depending on the tuner, they might be able to find the leak (if there is one)....
Smoke tests kick ass
