can someone tell me? - Subaru WRX Forum
post #1 of 6 Old 10-05-2004, 11:47 AM Thread Starter
Ian
Ian's Avatar
Ian is more helpful than not
Send a message via AIM to Ian
Can someone please tell me where the pcv valve is on the 04 wrx, I want to replace mine but can't seam to find where it is. Pictures would be nice to if you can, Thanks
Ian is offline
post #2 of 6 Old 10-07-2004, 01:22 AM
AZ-Scoob's Avatar
AZ-Scoob is an unknown
Send a message via MSN to AZ-Scoob
the pcv valve is located below the throttle body, right below the throttle cable. cannot be seen easily, but it is removed by first pulling the intercooler, then removing the molded line going to it, it is removed with a 19mm socket. (if you look at your engine just below the throttle body you can just see it, points slightly downward. I will be replacing mine shortly, and will be taking pics to document the whole process. need more details pm me and I can walk you through it if needed
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
AZ-Scoob is offline
post #3 of 6 Old 10-07-2004, 02:54 PM Thread Starter
Ian
Ian's Avatar
Thanks for the info it helped alot and it turned out that the dealer gave me the wrong one too, I guess they have 3 popular pcv valves for the WRX. Thanks again
Ian is offline
post #4 of 6 Old 10-08-2004, 04:18 PM
jwtarbaj's Avatar
Images: 11
jwtarbaj is more helpful than not
My understanding is all the current vehicles use the same part? Maybe the parts gy is an a$$clown?
jwtarbaj is offline
post #5 of 6 Old 10-08-2004, 07:41 PM Thread Starter
Ian
Ian's Avatar
I tried to change the PCV valve today and holy crap that thing is in there so tight i could not get the dam thing out. Does anyone know of any tricks?
Ian is offline
post #6 of 6 Old 10-09-2004, 10:53 PM
AZ-Scoob's Avatar
I usually gently tap on the ratchet handle with a small tack hammer loosening and tightening to try and break it free, probably has some burnt oil on the threads acting like lock-tite
AZ-Scoob is offline
