A/C Not working - Subaru WRX Forum
post #1 of 12 Old 04-04-2011, 11:56 AM Thread Starter
wrxsnowman's Avatar
wrxsnowman is an unknown
A/C Not working
So a few months ago my A/C clutch would start having a very rough engagement. Mind you, this was when it was still cold outside it would still engage when the heater was on. The engagement was really harsh, and you could hear the clunking when it would engage. Now, that it is starting to warm up, it doesn't make that noise, nor does it even come on. Also, during this time, I would hear a hissing coming from the firewall, near the dash, kinda like the freon would be leaking out. But it did that before when it came on and still cooled just fine. However, now the A/C doesn't even turn on. I'm thinking maybe a switch went bad, and maybe I just need to replace the A/C compressor clutch. any Ideas?
wrxsnowman is offline
post #2 of 12 Old 04-04-2011, 12:08 PM
Sounds like the clutch on the compressor has kicked the bed, although I am no A/C expert you'd be best off by getting a professional to look at it
post #3 of 12 Old 04-04-2011, 12:31 PM
+1
Also chk a simple relay
post #4 of 12 Old 04-04-2011, 01:04 PM
VD5505's Avatar
Well there are two ways you can go about this.
1- take it to a shop and have them fix it.
2- you will have to find the leak by buying a kit that will come with dye and you look for the leak. What might of happened is you had a leak the system was running low and you starved your A/C compressor from oil. When your A/C pressure gets low the low pressure sensor will trigger and it will shut your A/C off to help protect your system.
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #5 of 12 Old 04-04-2011, 08:10 PM
wagonracer's Avatar
Typically the o-rings on the compressor connections are the first to leak, and I would guess that's what happened. You leaked out the charge, and without one the compressor doesn't engage.
DIY, it's not that complex. You will be able to tell if the compressor and clutch are alright by just putting a charge in, whether it's R134 or leak finder. Be careful not to get carried away with the off the shelf stuff with oil already in it. Too much oil in the system will inhibit cooling.
Get the correct o-rings from Subaru, as many o-ring assortments don't hold up to AC applications (and may not fit quite right)
wagonracer is offline
post #6 of 12 Old 04-05-2011, 02:46 AM Thread Starter
wrxsnowman's Avatar
So, if I just just do a basic charge, or whatever to find the leak...then fix it and then have it professionally charged? I do all my own work on my car, other than A/C which I don't have much exp with.
post #7 of 12 Old 04-06-2011, 03:26 AM Thread Starter
wrxsnowman's Avatar
So I did the charge with dye, so I'm running it for a few days to see if I can find a leak. However, my compressor clutch is still engaging hard, and kinda makes like a metal to metal sound almost. I don't know, but I checked to see if I could get a clutch from the dealer. It looks like I have to buy the whole unit just to fix the clutch if it is infact worn out. It is cooling very well, and is working normal, but I haven't found any leak thus far. Just a loud clutch...any thoughts?
post #8 of 12 Old 04-06-2011, 09:13 AM
VD5505's Avatar
Is there any dust material on the back side of the clutch??
Brian
VD5505 is offline
post #9 of 12 Old 04-06-2011, 07:09 PM
wagonracer's Avatar
The clutches definitely fail. At almost 180K miles, I'm on my third, but being the cheap bastard that I am, I just pick up used compressors on e-bay or where ever for $25-$35. Usually I get 60-80K miles out of them. It didn't used to be possible to purchase the clutch only, but that may have changed. A small oil charge in the system can sometimes get a little more life out of them, but note my earlier post.
post #10 of 12 Old 04-07-2011, 01:04 PM
Andersonreid is on thin ice
Question
Not to # thread jack but has anyone done an A/C delete on on 02? i'm thinking about tearing mine out solely because i never, ever use it. Just wondering on how big of a job it is.
Andersonreid is offline
post #11 of 12 Old 04-07-2011, 02:08 PM
I just did one, it's not too bad just takes a while to remove everything
post #12 of 12 Old 04-07-2011, 02:17 PM
wagonracer's Avatar
If you are just deleting it for the power drain, a pair of tin snips to remove the belt is all you need.
If you want to loose the weight, four long 14mm bolts hold the compressor to the bracket, and one 14 holds the small bracket to the engine. They bottom right one is a PITA.....
2 12mm hold the tensioner bracket. You'll have to remove the radiator and grill in order to remove the condensor.
short answer: not too hard
