Hi all .
Did a motor rebuild on a 2003 WRX. Installed a new clutch kit and was having problems with clutch pressure. Clutch pressure issue was resolved with a new slave cylinder. After it was all put back together I still had the problem of the clutch release bearing popping out of the collar that is connected to the flywheel. Can anyone tell me if this is a common issue with the clutch collar.
Do I need to put in an aftermarket heavier duty clutch collar or is there another reason my clutch release bearing is not staying engaged in the release bearing.
Is the new slave cylinder pushing too hard on the fork.
Any answers will help amd save money. Thanks.
