BPV removal - Subaru WRX Forum
post #1 of 4 Old 11-20-2010, 03:54 PM Thread Starter
mfarnham's Avatar
mfarnham is an unknown
BPV removal
I'm trying to swap out my BPV but I can't get the larger hose off. What did you guys have to do? And yes I loosened the clamp.
mfarnham is offline
post #2 of 4 Old 11-20-2010, 06:37 PM
used the factoy Hose, when I still had recirc setup
post #3 of 4 Old 11-20-2010, 08:01 PM
wagonracer's Avatar
If you are swapping it out with another OEM one, just remove the elbow fitting from the BPV (two or three screws, IIRC) and mount that to the new one. That way you don't have to remove the hose.
I can't really think why that hose would be hard to remove, but I see you're in rust and corrosion country. If the suggestion above doesn't work for you, try spraying some PB Blaster or similar in there, wait a few minutes, and use a pair of channel locks to give the hose a twist to free it up. Then it should pull right off.
wagonracer is offline
post #4 of 4 Old 11-21-2010, 07:42 AM Thread Starter
mfarnham's Avatar
Ok ill give the PB Blaster a try. Thanks.
mfarnham is offline
