boosting problem please help this is a new one - Subaru WRX Forum
post #1 of 24 Old 03-12-2007, 01:33 PM Thread Starter
AWDnewby is an unknown
ok i have an 02 WRX when i bought it it felt sluggish i put an electronic boost controller on it and took it off the next night relizing that was a mistake but the car boosted up to like 1.5 bar with that controller so no boosting leak or anything
well i took it all off and was running only .5 bar 7 psi boost i have no intake leak or boost leak i don't belive because of the high boosting with the EBC well i disconnected the solonoid from the turbo to run full waste gate boost and it still only wen tot 10 so i'm wondering if i hav ea wastegate problem or if there is something else that is the matter because with that line unhooked i shold be running full turbo pottential and i have checked the turbo and there is no damage or shaft play at all so please help with any ideas
AWDnewby is offline
post #2 of 24 Old 03-12-2007, 02:13 PM
wagonracer's Avatar
Somebody will jump in and explain better than I can, but the stock BCS requires a restrictor pill in the vacuum line between the compressor out and the waste gate actuator. with out it you will only see 7-9 psi of boost. If you're running without the solenoid I have no idea what will happen, but I would think bad things. My car had a MBC on it when I got it and I put the vacuum lines back to stoc k so my EM could do its job. Much better...
wagonracer is offline
post #3 of 24 Old 03-18-2007, 04:35 AM
SubiGURU is an unknown
Just get a 3 port boost solenoid
SubiGURU is offline
post #4 of 24 Old 03-18-2007, 10:28 AM
Id check to make sure it is all connected correctly, that pill is very important and like wagoracer said. here is a picture of the connections
nagyhead is offline
post #5 of 24 Old 03-19-2007, 03:02 PM
svwannabe is an unknown
there is also that brass pill in the line connecting the t to the turbo. Quick question i just re-installed my factory boost controller and can remember which line goes to where on the boost controller. Can someone explain, Thanks.
svwannabe is offline
post #6 of 24 Old 03-19-2007, 03:15 PM
wagonracer's Avatar
One line goes to the T (wastegate accuator/compressor outlet) The other line goes to the turbo inlet hose (up at the MAF end) I'm not by the car, and my memory isn't good enough to tell you which one goes where on the BCS. Somebody with more brain cells left will be able to answer that one, or I'll check on the car later. Cheers
post #7 of 24 Old 03-24-2007, 07:52 AM
iwantone is an unknown
Send a message via AIM to iwantone
what you are showing as the pill. well mine broke so i put a vacuum line connector between them. when i looked insied that little piece that broke it was strait thru the piece. should i get one of these new from the dealer? i dont really notice any different with the connector i put in there....let me know. thanks
iwantone is offline
post #8 of 24 Old 03-24-2007, 01:04 PM
humanwrx's Avatar
humanwrx is an unknown
I have the same problem, To start my pill was in the wrong place. I switch the hose from the wastegate with the pill in it to the other side and now iam boosting at .1 insted of .05
humanwrx is offline
post #9 of 24 Old 03-24-2007, 01:34 PM
ohhNOwrx's Avatar
ohhNOwrx is an unknown
Nagyhead the pill has to go between the turbo and the T connector, the arrow that you showed is just a connector. I have worked on many wrx's and that's where the pill sits. Humanwrx it looks like that you have the pill after the T connector and it's going to the wastegate, try replacing the lil hose and get it between the turbo and T connector.
http://i112.photobucket.com/albums/n...mp007/PILL.jpg
ohhNOwrx is offline
post #10 of 24 Old 03-24-2007, 02:38 PM
oh, you are right, my bad. I did label it wrong. sorry for the confusion
nagyhead is offline
post #11 of 24 Old 03-24-2007, 03:18 PM
humanwrx's Avatar
I did yesterday and it made my wrx boost correctly at .1mpa and For a whole year of owning the car it was only hitting .05... sad I should of figured it out sooner
The previous owner must of had a MBC and hooked it up wrong before trading it in.
humanwrx is offline
post #12 of 24 Old 05-09-2007, 10:52 AM
awdturb is an unknown
where can one get a lil brass pill?????
awdturb is offline
post #13 of 24 Old 05-09-2007, 12:17 PM
squidz's Avatar
squidz is more helpful than not
If you are running a stock solenoid, get the pill from a subie dealer to ensure you get the right size. There are a lot of companies out there that offer pills of varying sizes for different turbo / solenoid / EM combinations. So be careful you get the stock one.
--Squidz
Sonic Yellow Bugeye
a.k.a. - "Amber"
squidz is offline
post #14 of 24 Old 05-10-2007, 07:09 AM
thanks guy
awdturb is offline
post #15 of 24 Old 05-15-2007, 10:12 AM
went to the dealer and ordered my pill cost $1.50. great deal. also i saw the SPT cat back in the show room for $495. almost bought it on the spot but the muffler looked a lil to conservative for me....whats everyone think about the spt catback...sound and performance?????....i dont mind something loud if it renders more performance....
awdturb is offline
