boosting issue - Subaru WRX Forum
post #1 of 13 Old 02-09-2010, 01:14 AM Thread Starter
suby_doo's Avatar
suby_doo is an unknown
Send a message via Yahoo to suby_doo
boosting issue
ok i have an 04 WRX with tbxs TBE and fuel rails, SPT intake, larger topmount intercooler with perrin y-hose, agency power crank pulley and a ported tgv delete.....
my problem is the car is only hitting 7-9lbs....
i used to have a EBC hooked up to it and it would get 16lbs constantly..... then tragedy struck one day it was only getting 7lbs.... i removed the EBC and went back to factory setup but still 7lbs of boost..... traced one issue to a cracked hose on the intake manifold i replaced that thinking that was the problem...... drove the car but still got 7lbs..... a buddy told me that i was missing the restrictor pill and that was causing the boost problem so i ordered an new t-hose for the wastegate and turbo but that only made the car hit 9lbs constantly..... what is going on with the car i need help and all this was going on before the tgc delete if that helps car also has no boost leaks.....
PS.
im running a tbxs utec stage 2 map
suby_doo is offline
post #2 of 13 Old 02-09-2010, 07:44 AM
So you just admitted to the car having TWO (2) boost leaks? Think that could possibly be the issue there?
post #3 of 13 Old 02-09-2010, 01:10 PM Thread Starter
suby_doo's Avatar
i meant no boost leaks that was a miss type
suby_doo is offline
post #4 of 13 Old 02-09-2010, 01:46 PM
Have you tried tightening your wastegate actuator arm? If you hear a lot of wastegate flutter that may be it, it can't stay shut with the reduced back pressure of the TBE. Basically the wastegate stays open since it doesn't have enough tension to stay shut, and bleeds off extra exhaust gasses.
post #5 of 13 Old 02-09-2010, 11:51 PM Thread Starter
suby_doo's Avatar
i havent tried that actually.... i'll give it a shot thanks
suby_doo is offline
post #6 of 13 Old 02-11-2010, 09:59 PM
WTRacing is more helpful than not
look for more boos leaks.... pull the neg battery cable and step on the brake for a a few sec then hook the battery cable back up....give that a shot
WTRacing is offline
post #7 of 13 Old 02-11-2010, 11:41 PM Thread Starter
suby_doo's Avatar
is that resetting the ecu........ does it matter that im running the utec
suby_doo is offline
post #8 of 13 Old 02-12-2010, 12:03 AM
it should reset the utec as well its worth a shot
WTRacing is offline
post #9 of 13 Old 02-13-2010, 10:20 PM Thread Starter
suby_doo's Avatar
would a build up of gunk on the inlet tube cause a problem...... my inlet is full of oil build upand while it was off i checked the turbo for shaft play and it has none.......
suby_doo is offline
post #10 of 13 Old 02-13-2010, 10:52 PM
VD5505's Avatar
With the car running get yourself a can of brake clean or carb cleaner and start spraying it around your BPV, Throttle, and intercooler tubing and hear to see if your car changes how it sounds when its idling, and if it does that is where you have a leak, Another way you can check for leaks is to pressurize your intake system but that takes alot of blocking off and knowing what you are doing to do that. Give ALL your hoses a good looking over as well to check for leaks and or cracks as well.
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #11 of 13 Old 03-09-2010, 04:42 PM
Myzkoo is an unknown
Could you figure it out? Did you get your boost back? If so, what caused the low boost issue?
/ Mattias, Sweden.
Myzkoo is offline
post #12 of 13 Old 03-25-2010, 07:50 PM Thread Starter
suby_doo's Avatar
still havent gotten my boost back
suby_doo is offline
post #13 of 13 Old 03-26-2010, 05:18 AM
Come over, i'll help you look around. PM me for my cell #.
