boost problem? - Subaru WRX Forum
post #1 of 20 Old 06-29-2004, 04:46 AM Thread Starter
boost problem?
i own a 99 wrx and am currently reading 7-8 psi. i have a straight through exhaust and a blow BOV. no boost controller. i have been told that it should be boosting to about 14 psi. there are also places that tell me that a stock wrx can sometimes boost to 8 due to restrictions between the turboa nd teh cooler to reduce exhaust noise when they were built. there has also been advice that suburu ( dealers) will boost your car back down to 8 when you bring it in for a service as thats is what its supposed to be on. i brang myc ar to suburu to have the major service and got a boost gauge after so am no sure as to if they did it. any info will be appreciated.
sickem is offline
post #2 of 20 Old 06-29-2004, 06:36 AM
Tut4u2's Avatar
Images: 11
What boost gauge do you have? And at what RPM are you getting that boost?
Che
Tut4u2 is offline
post #3 of 20 Old 06-30-2004, 12:42 AM
BWReX's Avatar
Images: 13
Also, what gear are you reading it at?
BWReX is offline
post #4 of 20 Old 07-01-2004, 05:57 AM Thread Starter
its in every gear. it even hits max boost in first gear. i got an autometer gauge.
sickem is offline
post #5 of 20 Old 07-01-2004, 10:44 AM
IBAUCLAPlaya's Avatar
Is the gauge electronic or manual?
IBAUCLAPlaya is offline
post #6 of 20 Old 07-04-2004, 12:18 AM Thread Starter
its a manual one
im quite confident the gauge is accurate
sickem is offline
post #7 of 20 Old 07-04-2004, 07:32 AM
Kobiyashi's Avatar
Originally posted by sickem
its a manual one
It would be very weird (even for that low of boost) to hit the same number in every gear, however possible. I would look into the boost gauge before I would call it a problem though, the boost guage sounds to me like it very well might be off. Have you done any other mods? Did you make sure all vacuum lines are connected in the bay? Hope this helps a little.
-kobi
Kobiyashi is offline
post #8 of 20 Old 07-04-2004, 07:42 PM
Buy an electronic gauge like Greddy, Defi, etc. Then see what happens.
post #9 of 20 Old 07-04-2004, 07:49 PM
BlueDemon's Avatar
8 psi is about where the wastegate kicks in if there is no boost selenoid activating or boost controller to up the pressure. When my boost selenoid went bad I was boosting 7-8 psi in all gears. Instead of speding alot of money at the dealer to have them fix it, I just opened up the ABC. Check to make sure all connections are in correctly. If yes, then you probably have a bad selenoid/stock boost controller. Go out and buy an MBC or EBC.
Blue
BlueDemon is offline
post #10 of 20 Old 07-11-2004, 06:23 AM Thread Starter
so if i put in a boost tap there should be no problem? the stock solenoid has just gone bad and it doesnt need to be replaced? can someone explain how boost control works. i know that the solenoid electropnically controls the wastegate but ive also heard that the actualtor does. this seems to be the difference between mbc and ebc but i dont get how the both work together. like if my solenoid is bad can i just use the actuator to boost up?
sickem is offline
post #11 of 20 Old 07-11-2004, 10:31 AM
BlueDemon's Avatar
Both an MBC and an EBC bypass the Stock Boost Controller, so I don't know exactly what you're getting at?
Blue
post #12 of 20 Old 07-15-2004, 09:24 AM
Solice's Avatar
Send a message via AIM to Solice Send a message via Yahoo to Solice
I noticed a while ago that in 2nd and 3rd my boost peaks at 8 psi. I'm going by the factory boost gauge that subaru installs though. Not sure what 1st peaks at, rpm's shoot up too quick
Solice
Solice is offline
post #13 of 20 Old 07-15-2004, 09:39 AM
The stock boost gauge is known to be unaccurate.
post #14 of 20 Old 07-15-2004, 09:49 AM
Solice's Avatar
Nice, that's what I'm hoping. The turbo timer I'm getting has a digital boost gauge so I'll see what that reads
Solice is offline
post #15 of 20 Old 07-15-2004, 10:28 AM
Are you getting the Blitz DTT. I think my boost gauge is accurate because my DTT reads about the same as the stock boost gauge maybe .01 hkpa different
