» Sponsor Links
»Garage Storage and Cabinets
Old 11-25-2007, 11:28 PM   #1 (permalink)
ImNASTI's Avatar
Reputation: ImNASTI is an unknown
Send a message via Skype™ to ImNASTI
Cool Boost leak?
Hey guys, new to the fourm here, need some help/ advice
I have a 02 wrx with a few mods. I'm sure that I have an exhaust leak somewhere. Some times when traveling down the highway in 5th gear whenI give it the gas i can hear a constant WHOOSH. I have a boost guage and it dosen't fall off untill I let off the gas. Could my exhaust leak be the source of that sound??
Some times when I'm ripping through second gear i cant hear it , (i have a 3 inch pipe from the turbo back) but it seems like its not boosting as hard as it should. Again, I wonder if it could be the exhaust leak. I have a BOV and a Manual boost controler (I read now that most of you dont like them, so dont yell)
Any advice/ things to check??
Thanks
P.S. Anyone in the PSL area in FL?
Old 11-26-2007, 07:19 AM   #2 (permalink)
A boost leak and an exhaust leak are two different things.Exhaust leak is easy to check.Let the car idle,put on e-brake.Go to the back of the car with a couple of shop rags.If you have a buddy handy have him get down on his kness by the front of the car.Take the rags and plug the exhaust tip with them for a couple of seconds.If you got an exhaust leak,you will hear it.Basicly how they do it for saftey inspections.The Whoosh is either your turbo or BOV.Pre-turbo exhaust leaks are more like whistles.Boost leaks are found by pressurizing the intake tract.You will need to make an attachment to do this and have a air compressor handy with an adjustable regulator.
Aarg matey!
ECU Pirated by RomRaider
Old 11-26-2007, 06:06 PM   #3 (permalink)
SWFL Scooby's Avatar
Club Region: Southeast
Reputation: SWFL Scooby is an unknown
....What he said... and I am in Naples, FL, probably 2 hours from you
D-Rock
Under constant pressure
Old 11-26-2007, 11:09 PM   #4 (permalink)
ImNASTI's Avatar
thanks guys, I'm gonna check that out tomorrow
