Boost comes and goes - Subaru WRX Forum
post #1 of 15 Old 09-12-2010, 10:17 PM Thread Starter
Skillet is an unknown
2002 wagon, bone stock. 125K. Recent maint: fuel pump/filter, air filter - clean MAF, timing belt, PCV. When boost is working it works perfectly. Sometimes is fades to nothing when driving, sometimes it starts that way. Most times I can turn the car off, restart and boost will be there. I've checked: isolate wastegate - begins to open at 9 psi, full open by 15 psi, smooth operation. Vacuum lines OK. Intake hoses/connections OK. Clean and check stock boost controller - couldn't get to fail. If I unplug vac line to BC to bleed pressure, I never lose boost. Seems like the ECU is closing the boost controller - it doesn't act like a loose wire, and I haven't found anything mechanical. I've reset the ECU, no CEL's. Any ideas on what else I can check? Thanks.
Skillet is offline
post #2 of 15 Old 09-12-2010, 10:37 PM
have you tried switching out Boost Controller Solenoids...to me that's what it sounds like is the BCS is failing...try swapping with a friend
post #3 of 15 Old 09-12-2010, 10:58 PM Thread Starter
I agree, I was hoping it was gunked & sticking shut. Had it on the bench & cycled it a hundred or so times, it worked perfectly so I moved on. I'd have to buy one, maybe I should test it some more.
Skillet is offline
post #4 of 15 Old 09-14-2010, 03:38 PM
anxiouz's Avatar
anxiouz is an unknown
When you say boost "sometimes fades to nothing"...does it hit normal boost and then just taper down really quick?
Does it build boost normal or slower?
Does it hit wastegate boost pressure at least?
I dunno what wastegate boost is on a wrx but on my evo it's around 10-11psi give-or-take. When I had a wastegate solenoid go bad I would only boost to 11psi (usually more slowly than normal) and it would never go above that. A bad solenoid will just leave the wastegate open as a safety precaution if it thinks there's a problem. Kinda sounds like what you're experiencing.
But since you tested that out a bunch of times...my guess is it's electrical. It took me forever to find a slightly freyed (ECU-to-solenoid) wire once. I had to trace the whole thing but as soon as I taped up the kinked wire to maintain the proper connection, it fixed my problem. It stumped a dealer for several days on repeated trips so it was extremely difficult to locate though.
anxiouz is offline
post #5 of 15 Old 09-16-2010, 09:35 PM Thread Starter
Mostly it's there or it isn't. A few times it has started out OK, then delivers what feels like maybe 1/2 max boost before no boost. Well I was wondering what else the ECU looks at for BC operation - components I can check. You are right about a thorough check out of the wiring, thanks.
Skillet is offline
post #6 of 15 Old 09-20-2010, 12:52 PM
anxiouz's Avatar
Any chance that the behavior is temperature related? Like it works fine when the car is cold but when it's hot you start having issues? That would point to IC piping couplers possibly heating up, expanding, and leaking a lil.
Otherwise I'm stumped. It sounds like you've checked everything thoroughly.
And when I was having solenoid issues I was throwing CEL codes. So for you to not be, that's even more strange.
anxiouz is offline
post #7 of 15 Old 09-22-2010, 07:57 AM Thread Starter
I'd have to say not. I'm considering changing the stock setup at this point - maybe a manual bc. If I have to throw money at it I want to know it's going to work. It's the wife's car & she doesn't hot rod it, so maybe that's an OK option. Thanks for the input.
Skillet is offline
post #8 of 15 Old 09-22-2010, 08:29 AM
Never is an MBC ok especially without a protune, partial throttle full boost will grenade the hell out of your motor
post #9 of 15 Old 10-01-2010, 08:15 AM Thread Starter
Roger that, good advice. I'm gonna buy her a bus pass.
Skillet is offline
post #10 of 15 Old 01-05-2011, 04:43 PM
tylorsanchez is an unknown
hey guys i need help so me and my friends were messing around halling as in my rex and i blew out my mass flow senser but now my turbo wont kick in and it sounds like its just blowing out like my psi's will not go above 5 even when my turbo is turned up. so i am really lost on were the problem could be. please halp
tylorsanchez is offline
post #11 of 15 Old 01-05-2011, 09:50 PM
When your turbo is turned up? What mods, how many miles, what have you checked? More detail/information could help us help you much better and quicker.
post #12 of 15 Old 01-06-2011, 07:18 PM
alright well is an 02 with about 90 k on it but it has no big mods i have done nothing sense i bought it andthe guy who had it befor me did nothing sorry man dont have this engine figured out yet so just throw me ideas
post #13 of 15 Old 01-07-2011, 05:20 AM
Start your own thread and more people will respond and help you
post #14 of 15 Old 03-04-2011, 11:49 PM
WRXGurl's Avatar
WRXGurl is an unknown
I've had the same problem on my 03 as the original poster... I will boost under half throttle but it will go to .07 bars and stay. It feels as though it has no power and the boost will not budge about this. I have a turbo timer and aftermarket BOV but I have checked my system and it's not leaking. Other days it will boost to .1 bar and hold beautifully... next min it pegs at .07 and starts dogging. When I bought the car it has a Subaru tuning sticker on it but can't find anyone local to reflash... it has 178,000 miles and runs strong. Just looking for Ideas since all the info on the solenoid says it wouldn't boost all the way with it malfunctioning and I have no CEL other than the occasional P0420 due to my cobb exhaust.. any ideas?
WRXGurl is offline
post #15 of 15 Old 03-05-2011, 08:23 AM
You said you have a cable and a logging program. Log the car and see what the IAM is and if it dropping. You need to list ALL performance mods done to the car. If the car has been modded and not tuned for the particular parts then your going to have issues. I can already tell there is no EM because you have a CEL/DTC for the exhaust. Read this.........
Unabomber's Manifesto - NASIOC
dumdum is offline
