Boost braking up - Subaru WRX Forum
post #1 of 4 Old 01-16-2011, 05:11 PM Thread Starter
unlucky2267 is an unknown
Boost braking up
ok here is the deal i am only getting 10psi out of the turbo. and at around 5psi the boost brakes up BAD shakes the whole car and motor, car srives fine when i shift before boost. i seafoamed the motor and found a large a mount of smoke comes out of the right hand side of the exhaust manifold now here is the question think it might me a exhaust gasket if not then the right hand side manifold that bolts to the motor is cracked so where can i find a good exhaust manifold for like 200 dollors that will not just fall apart at the welds or not fit right. please help i might as well just do a full exhaust from the manifold back. i am pulling the stock uppipe off the car this weekend and installing a cat-less one and a ca-tless down pipe so if its not just a exhaust gasket i might as well replace the manifold also. its a 02 WRX by the way http://www.wrxtuners.com/forums/imag...s/confused.gif
unlucky2267 is offline
post #2 of 4 Old 01-17-2011, 05:48 AM
Buy a used stock one... Go on NASIOC.com and search the classifieds... Only thing you will get for $200 is an eBay piece... and I'd stand clear of them anyways. I have seen manifolds crack in the past but this was due to running into a snow bank and with no undertray on the car. Try the gasket 1st because even if it's not the problem, you will still need a new gasket for another manifold.
PM me if you are looking for a stock manifold.
post #3 of 4 Old 01-17-2011, 08:49 PM Thread Starter
not to worried about the welds on the ebay manifold i was just going to re-tig the welds so they dont crack. at the sametime i dont want to buy one off ebay. ya i was going to replace the gasket anyway to see if that works thanks
post #4 of 4 Old 01-18-2011, 12:14 PM
Hondafan's Avatar
You were the one who was worried about the welds. Anyway, good luck. Try to proof read your posts so they are easier to understand them.
Hondafan is offline
