blue smoke on start up - Subaru WRX Forum
post #1 of 13 Old 11-22-2010, 03:24 PM Thread Starter
scoobyrooftw's Avatar
scoobyrooftw is an unknown
whenever i start my car for the first 5 seconds or so it funs really rough and blows a huge cloud of blue smoke. after that it smooths out and runs fine with no smoke. it didnt do it until i changed my oil. i used the same oil and filter as i always do and didnt do anything different when i changed it. what could it be??
scoobyrooftw is offline
post #2 of 13 Old 11-22-2010, 06:01 PM
rex2002's Avatar
in most cases a blue/white smoke is a blown head gasket
rex2002 is offline
post #3 of 13 Old 11-22-2010, 06:34 PM
Not true...White smoke is typically a Blown HG...BUT blue smoke is typically bad valve stem seals, bad piston rings, broken/cracked ringland, a crack in the valve guide, cracked spark plug threads, blow turbo seals (although this would not be seen at startup usually) or overfilling an over change.
post #4 of 13 Old 11-22-2010, 06:38 PM
and with what the OP describes it sounds more like a cracked valve guide, or a bad valve stem seal
post #5 of 13 Old 11-22-2010, 06:42 PM Thread Starter
ok so how do i tell which it is? im due to change spark plugs in 2k miles so i could just do that now but what about the rest?
post #6 of 13 Old 11-23-2010, 05:27 AM
You COULD try to single it out and that would be your next step... OR.... pull the motor and have done with it.
EDIT: have you sent in an oil analysis lately?
post #7 of 13 Old 11-23-2010, 06:03 AM Thread Starter
no i havent. what would that do?
post #8 of 13 Old 11-23-2010, 11:51 AM
Might tell you if coolant is in the oil or not.... Also, if you do it every once in a while, you can also get a heads up on most problems.
post #9 of 13 Old 11-23-2010, 09:18 PM Thread Starter
today i drove my car to work. when i started it in the morning it did the same thing. when i started it to come home it ran normally and didnt have any smoke. this is the first time since it started doing it that i let it get up to temp. now im really confused. well see what it does tomorrow morning. also, i checked my to see if it was throwing a code and its not
post #10 of 13 Old 11-24-2010, 05:15 AM
The ECU will still store a code if it ever has had one and not been cleared manually.
post #11 of 13 Old 11-24-2010, 10:48 AM
Do it now and do a compression test. The plugs themselves will be a pretty good indicator as well. Be prepared for bad news.
post #12 of 13 Old 11-24-2010, 10:55 AM
blk05WRX's Avatar
This might seem a little easy, but since you said it just started after you changed your oil did you check to make sure it wasn't overfilled? Or maybe double check what kind of oil was used. Maybe it was too light of weight or something. I'd start there and at least change your oil again with the proper stuff before tearing your motor apart.
2005 WRX Cobb Stage 2
2009 Outback
blk05WRX is offline
post #13 of 13 Old 11-24-2010, 11:18 AM
^^ Good point.
