BiG Issue? weird noise - Subaru WRX Forum
post #1 of 23 Old 12-07-2011, 08:33 PM Thread Starter
WRXInfantryGuy's Avatar
WRXInfantryGuy is an unknown
im having a blow dryer like sound comming from my engine around the belt area at idol, while driving and very loud while turning. im hopeing its just a bad belt.
TJ Butler
WRXInfantryGuy is offline
post #2 of 23 Old 12-08-2011, 12:21 AM
Try disconnecting the AC belt and see if it goes away. I had my AC compressor bearing go bad and start making a ton of nose
post #3 of 23 Old 12-08-2011, 04:58 AM Thread Starter
Ok I'm Pretty new to this where is it located. Would it still make noise if I'm not running my A/C. Because I haven't benn running it and it still makes the noise I also noticed after driving for a while it gets really quiet and sometimes stops untill I slow back down again.
TJ Butler
post #4 of 23 Old 12-08-2011, 06:01 AM
So it still does it with the AC ON ?
Check the air pump as well. Might be a hose that came disconnected from the pump.
Since it's louder while turning, you may have a POS power steering issue. Did you check your fluid level.
post #5 of 23 Old 12-08-2011, 09:07 AM
If its what I said, it would make noise regardless of whether the AC was engaged or not. My Sti had that issue before I sold it. That belt is always turning the AC compressor wheel. But it does sound like your PS pump could be the culprit like Paul said.
post #6 of 23 Old 12-08-2011, 10:00 AM
BoostinChick is a helpful contributing member
^ x2 on checking the PS, considering the poster said it's louder when turning.
- Sandra
2007 WRX TR | Stage 2 | PAR Gearset (Built by AndrewTech)
BoostinChick is offline
post #7 of 23 Old 12-08-2011, 10:19 AM Thread Starter
I'll check the fluid and the ac belt but I don't know where the ac belt is
TJ Butler
post #8 of 23 Old 12-08-2011, 10:20 AM Thread Starter
How does the power steering make noise?
TJ Butler
post #9 of 23 Old 12-08-2011, 11:39 AM
The AC belt is the smaller of the 2 on the front of the engine (standing in front with the hood up).
What do you mean "How does the PS make noise?" It's powered by the other belt.
post #10 of 23 Old 12-08-2011, 01:12 PM Thread Starter
So how do I fix this problem
TJ Butler
post #11 of 23 Old 12-08-2011, 01:35 PM
Disconnect the PS belt. Drive the car. See if noise persists. Disconnect AC belt, drive. See if noise persists. If one of those fixes the noise, you know that the corresponding pump was bad.
post #12 of 23 Old 12-08-2011, 02:08 PM Thread Starter
Ok. Thanks
TJ Butler
post #13 of 23 Old 12-08-2011, 02:59 PM
ejs0806 is more helpful than not
also power steering makes noise when its going bad gets like a whine noise but shoulndnt happen unless you steering or if its making noise while sitting its kinda shot lol but no the noise you described doesnt sound like the pump itself going bad.. turn your car on while sitting and turn the wheel if it whine or the noise changes then its most likely the pump.. In my experiences if you max it out to the side where it usually makes a little noise it will be way worse
ejs0806 is offline
post #14 of 23 Old 12-08-2011, 07:33 PM Thread Starter
If it turns out not to be the pump any other ideas of what it could be maybe
TJ Butler
post #15 of 23 Old 12-08-2011, 08:06 PM
Start there. The fact that it gets louder when you turn is a good indicator.
