bad pulley possibly - Subaru WRX Forum
post #1 of 8 Old 03-11-2012, 10:51 PM Thread Starter
ejs0806 is more helpful than not
bad pulley possibly
i have a whining noise ive noticed on and off lately noticed it a few weeks ago then it went away its been windy here the past few days with a lot of dust. I noticed a bad on and off whining/kinda grindy when cold starting now it goes away once i start driving but i can still here a slight whiny noise.. Its really the best way i can describe it. How would i be able to diag which pully it is, if it even is a bad pulley.
ejs0806 is offline
post #2 of 8 Old 03-12-2012, 06:26 AM
You sure it's not a belt?
How many miles are on the car?
What have you done to it lately?
post #3 of 8 Old 03-12-2012, 08:43 PM Thread Starter
110K and i havnt touched her at all in the past month or too. And it doesnt sound like a belt sqeal to me which is why i questioned it
ejs0806 is offline
post #4 of 8 Old 03-13-2012, 06:41 AM
Have you done the timing belt/water pump/etc. yet?
post #5 of 8 Old 03-13-2012, 09:27 AM Thread Starter
No I havnt done it yet
ejs0806 is offline
post #6 of 8 Old 03-13-2012, 09:49 AM
mr mello's Avatar
mr mello is an unknown
Sounds very much like the A/C compressor pulley. Mine was the exact same way, squealing in the cold mornings then quieting as it warmed. By the time i got to the pulley(admittedly i had a new one riding in my glovebox for a month) the bearings had seized so badly the pulley had begun to melt around it. Not even a week later, exact same thing in my dads subaru as well.
mr mello is offline
post #7 of 8 Old 03-13-2012, 10:00 AM
I do know the AC bearings/pully take a dump fairly quickly on your car. That's why I asked if you were sure it's not a belt. But I'm with Mr Mello above. Only way to check it would be to cut the acc belt or take it off and see if it still does it.
post #8 of 8 Old 03-13-2012, 10:11 AM
mr mello's Avatar
No need to cut it. Just lower the alternator, take off the front belt, then detension the A/C pulley tension bracket(and be gentle doing it, as its a metal screw in a plastic piece that's more then likely been made brittle by 10 years of heat and cold) and pop out both the pulley and belt. If you cant hold the middle of the pulley and spin it freely with one finger, it needs to be replaced.
mr mello is offline
