Bad Leaking Injector After motor Install - Page 2 - Subaru WRX Forum
post #16 of 26 Old 03-09-2011, 10:53 AM
No, one sensor and one motor on each TGV.
dumdum is offline
post #17 of 26 Old 03-09-2011, 02:12 PM
Originally Posted by Phatnucca View Post
one sensor in the front and one in the back correct? And driver side for sure? Ok i'll check
Dumdum's answer is correct. With your CEL bank 2 error indicating you need to check the driver's side TGV position sensor.
post #18 of 26 Old 03-09-2011, 06:53 PM Thread Starter
Send a message via AIM to Phatnucca
Yea i checked. its plugged in, but apparently not working the the butterflies are stuck closed on that side. Anything under 4K rpms pulls normal.. andything about that just feels and sounds like its getting a ton on fuel... yet not enough air.
07 WRX TR-12.7@106
Invidia Catless DP,Invidia Catback,SPT Intake,Stage2Protuned,Large TMIC
Phatnucca is offline
post #19 of 26 Old 03-10-2011, 05:36 AM
I bet you have to reset the TGV "motors". Has anyone played with them, ie... unscrewed them?
post #20 of 26 Old 03-10-2011, 03:48 PM Thread Starter
idk if that will do anything if the sensor itself is bad. If that motor is not functioning then that means the tgv on that side will not open correct? And those 2 cylinders driver side will not be getting enough air? Thats what it seems like it going on. I was thinking about just taking the butterflies out. idk..
07 WRX TR-12.7@106
post #21 of 26 Old 03-11-2011, 06:00 AM
Correct... Assuming all years TGV motors are the same, I can get a new one to you. PM me if you like. But below is the delete.
Here ya go :
Results for TGV Deletes
Depends which one you have
post #22 of 26 Old 03-12-2011, 11:52 AM Thread Starter
Well, does anyone know at all that if the bank 2 TGV motor is in fact not working and the butterflies are stuck shut it will fall on its face at about 4K rpm's? Sounds like its just getting a ton of fuel and no air to those 2 cylinders. If those 2 butterflies are stuck shut would it make it run like that
07 WRX TR-12.7@106
post #23 of 26 Old 03-12-2011, 01:13 PM
Uhh..what do you think? I would say yes..........
dumdum is offline
post #24 of 26 Old 03-30-2012, 02:46 PM
I am having the same problem.
P2021 - It says intake manifold runner position sensor low circuit - bank 2
Now i have been so looking into it that i know a lot about it except when it says bank 2 i know it's driver side - now there is front and rear - the front sensor can't be sold separately according to the dealer and the one in the rear is separate. So which one has to be changed - if any body knows - help would be appreciated. The front is a piece of the intake manifold and costs 400 - the rear like 170 something like that.
Checked all the wiring and everything but this code is gonna kill me. Thanks for any help R.
STI379 is offline
post #25 of 26 Old 04-02-2012, 06:29 AM
^Is it falling on it's face at 4-5K?
post #26 of 26 Old 04-03-2012, 05:59 PM
No it's not.
Today i took the rear sensor out and checked and it's working fine.
So now i am assuming it's the front sensor. Lucky me.
STI379 is offline
