Automatic tranny wont shift from park - Subaru WRX Forum
post #1 of 6 Old 05-13-2012, 01:35 PM Thread Starter
mikes03wrx is an unknown
In my 03 wrx i went outside and it decided not to shift out of park. Its seems like when you dont push on the brake. So i figured that is the problem. i just wonder where I should start with this. is it a fuse, a wire, and if so where would be the best spot to start looking for the trouble?
mikes03wrx is offline
post #2 of 6 Old 05-13-2012, 05:40 PM
wagonracer's Avatar
First off, there is a way of overiding that, so you can drive it. There's a little cover next to the shift lever (smaller than a dime) that you pop open, then push down the button under it to get the trans out of park.
The brake pedal switch is one of a few possible causes. There is also an inhibitor switch in the shift mechanism that can fail, the cable and bushing can bind, the park/neutral safety switch, the mechanism itself etc. Do you diagnosis thoroughly, or you could end up throwing a lot of parts, money and time at it trying to repair. Has anything (liquid) been spilled on or around the shifter ?
Cullen
wagonracer is offline
post #3 of 6 Old 05-13-2012, 05:49 PM
The hole with the lever saved my arse when I was at the beach(in my Caliber though)
And the switch at the pedal was my fix, thank god for phones with internet and forums
or my wife would have been a bit miserable...lol
post #4 of 6 Old 05-14-2012, 06:27 PM Thread Starter
Ok so new problem. First it was the fuse. But now when I hit the brake the left turn signal light comes on in the dash and the front turn signal light comes on. when i pull the fuse back out it stops. what does this mean?
post #5 of 6 Old 05-15-2012, 05:41 AM
You have a wiring issue. What did you do lately? (install)
post #6 of 6 Old 05-16-2012, 10:35 AM Thread Starter
I didnt do anything. Something must have fryed when the fuse blew. I just wonder if anyone else had a problem like this
