APEXi Turbo Timer does not work!
I own an 04' Subie STi. I recently had an APEXi TT installed with an HKS harness. Since the harness documentation was all in Japanese(which I cant read), I followed the TT install directions.
I had the ground, the e-brake wire and the ignition passthrough harness conected. I skipped the o2 sensor, I figure ill just set the TT to manual for now. The thing is I have the extra wire from the harness package, it looks like there is a resistor in the middle of the wire under some shrink wrap... but I do not know what to do with it or even if i need it.
Bottom line when I turn of the ignition the car turns off, and when I try to change the "TIME" setting to anything other thatn 30 secs, I cant get the TT in to setting mode. The only thing that does appear to work is the battery voltage display YAY!
Any help or links to better documentation would be greatly appreciated.....
Thanks
