AP v2 CEL HELP - Subaru WRX Forum
post #1 of 7 Old 11-22-2008, 10:50 PM Thread Starter
borlarex88 is an unknown
AP v2 CEL HELP
Hey guys, i just flashed to stage 1 today and after driving it for about 30 minutes (some aggressively, some normal) i got a P0171 code for running too lean (bank 1.) I stopped to tighten my BOV pretty much all the way closed (venting less air outside) and drove home about 5 minutes later with the light still on.
When driving normally, my A/F ratio was low 14s/high 13s and when driving more aggressively it was going from 14-21. I'm not sure where it is should be. Also, my boost looked pretty much where it should have been.
What can i do about this?
thanks
borlarex88 is offline
post #2 of 7 Old 11-23-2008, 01:56 PM
tuner ready's Avatar
Images: 11
tuner ready is an unknown
Take off your BOV?
tuner ready is offline
post #3 of 7 Old 11-24-2008, 09:41 PM Thread Starter
Originally Posted by tuner ready View Post
Take off your BOV?
BOV shouldn't be a problem now that its closed, i think its my cai. Thats what most people who have had the same problem have said. I'll just switch it out for the stock intake.
post #4 of 7 Old 11-24-2008, 09:56 PM
That would have been great if that was mentioned earlier. Both the BOV and the CAI arent even an upgrade for a WRX.
post #5 of 7 Old 11-24-2008, 10:54 PM
03 CrazyTaxi's Avatar
+eleventy billion! The stock intake with a modified snorkus is the only intake mod you need unless you decide to go to a FMIC. Same goes for the stock BPV. PUT IT BACK ON. Also, clean your MAF with some CRC Electrical cleaner and reset your ecu. Problem solved.
03 CrazyTaxi is offline
post #6 of 7 Old 11-25-2008, 04:48 PM Thread Starter
I dont have either, but will get a stock intake and keep the bov closed until i get a protune. Then i may put the cai back on and open the bov if i want to. The tune will allow those without problems.
post #7 of 7 Old 11-25-2008, 07:43 PM
The tune would probably help with the CAI, but not the BOV. You cant tune for one of those.
