-   -   AP v2 CEL HELP (http://www.wrxtuners.com/forums/f72/ap-v2-cel-help-24778/)
borlarex88 11-22-2008 11:50 PM
AP v2 CEL HELP
Hey guys, i just flashed to stage 1 today and after driving it for about 30 minutes (some aggressively, some normal) i got a P0171 code for running too lean (bank 1.) I stopped to tighten my BOV pretty much all the way closed (venting less air outside) and drove home about 5 minutes later with the light still on.
When driving normally, my A/F ratio was low 14s/high 13s and when driving more aggressively it was going from 14-21. I'm not sure where it is should be. Also, my boost looked pretty much where it should have been.
What can i do about this?
thanks
tuner ready 11-23-2008 02:56 PM
Take off your BOV?
borlarex88 11-24-2008 10:41 PM
[QUOTE=tuner ready;209756]Take off your BOV?[/QUOTE]
BOV shouldn't be a problem now that its closed, i think its my cai. Thats what most people who have had the same problem have said. I'll just switch it out for the stock intake.
newtothegame 11-24-2008 10:56 PM
That would have been great if that was mentioned earlier. Both the BOV and the CAI arent even an upgrade for a WRX.
03 CrazyTaxi 11-24-2008 11:54 PM
[QUOTE=newtothegame;209853]That would have been great if that was mentioned earlier. Both the BOV and the CAI arent even an upgrade for a WRX.[/QUOTE]
+eleventy billion! The stock intake with a modified snorkus is the only intake mod you need unless you decide to go to a FMIC. Same goes for the stock BPV. PUT IT BACK ON. Also, clean your MAF with some CRC Electrical cleaner and reset your ecu. Problem solved.
borlarex88 11-25-2008 05:48 PM
[QUOTE=03 CrazyTaxi;209868]+eleventy billion! The stock intake with a modified snorkus is the only intake mod you need unless you decide to go to a FMIC. Same goes for the stock BPV. PUT IT BACK ON. Also, clean your MAF with some CRC Electrical cleaner and reset your ecu. Problem solved.[/QUOTE]
I dont have either, but will get a stock intake and keep the bov closed until i get a protune. Then i may put the cai back on and open the bov if i want to. The tune will allow those without problems.
newtothegame 11-25-2008 08:43 PM
The tune would probably help with the CAI, but not the BOV. You cant tune for one of those.
