abs comes on when stopping - Subaru WRX Forum
post #1 of 6 Old 04-21-2010, 09:59 AM Thread Starter
scoobyrooftw's Avatar
this weekend i replaced my struts and springs, clutch, and put braided brake lines on. today i was taking it to get an alignment and i noticed that whenever i stop the abs kicks on when im almost stopped. it doesnt do it until ive slowed to like 2 mph. is this because of the brake lines? i also had to replace a rear wheel stud so i had to take the ebrake assembly apart. is it possible it just needs adjusted? one of our trucks at work the same problem and it turned out to be bad wheel bearings. could it be that?
scoobyrooftw is offline
post #2 of 6 Old 04-21-2010, 10:35 AM
It's probably not the brake lines. I have Goodridge SS brake lines all around on my 07 WRX and my ABS light has never come on.
post #3 of 6 Old 04-21-2010, 10:45 AM Thread Starter
its not the light. the actual abs comes on and pulses the brakes
post #4 of 6 Old 04-21-2010, 02:26 PM
Chk on the passenger firewall in the engine bay for the ABS goodies... you may have messed up the plug/or similar.
post #5 of 6 Old 04-21-2010, 04:38 PM
It sounds like it has something to do with a sensor somewhere. How could a bad wheel bearing cause the ABS to activate?
post #6 of 6 Old 04-21-2010, 04:38 PM
You probably just need to clean the ABS wheel speed sensors, most likely you did something to them while messing with your suspension.
http://ken-gilbert.com/wrx/STi_Manua...d%20Sensor.pdf
Ryan
2009 STi - Cobb Stage 2
VisiX is offline
