3000 rpm and above noise while driving, New to me - Subaru WRX Forum
post #1 of 3 Old 02-15-2010, 07:25 PM Thread Starter
Nekoawag04 is an unknown
I can't get it to make it while in neutral and it only makes it when I shift over 3000 rpm. I have had 2 car guys hear it and they thought it was just a heat shield or something that vibrated when those rpm hit. Really confused and would like to know if anybody else has had this happen to them. Thanks
Nekoawag04 is offline
post #2 of 3 Old 02-15-2010, 07:33 PM
turboner is an unknown
my 09wrx makes that noise rising past 2000rmp it has now stopped. the subaru tech said that it was noting to worry about. i would check the gears(to make sure the are not worn out from hard shifting) and the clutch to make sure its not slipping other than that i would check to see if something is loose in the front near the tranny. hopes that helps
turboner is offline
post #3 of 3 Old 02-15-2010, 08:26 PM Thread Starter
did yours kinda sound like a valve knock when you shifted?
