2nd gear deceleration noise - Subaru WRX Forum
post #1 of 12 Old 09-26-2003, 01:48 PM Thread Starter
Kev
Kev is an unknown
I have a grinding noise when I decelerate in 2nd gear(off the clutch), it is only at very low rpm's(2300-1600), like coming to a stop sign. If I touch the gas or disengage the clutch it goes away. It sounds like a heat shield rattling, (but, I don't think that's what it is). It has always made this noise, even when I test drove it, I asked about it and the Subaru techs said that the tranny in the WRX's make that sound and it is normal. I can take it because it is pretty quiet but I was wondering if other people have this sound.
Kev is offline
post #2 of 12 Old 09-26-2003, 02:56 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
You might have a loose bolt somewhere. But this is really odd, never heard anything like it before.
Che
Tut4u2 is offline
post #3 of 12 Old 09-28-2003, 12:41 PM Thread Starter
Kev
Kev is an unknown
dammit, I think I got a bum rex. I am going to the dealer tomorrow just to make sure, maybe it is a heatshield.
Kev is offline
post #4 of 12 Old 10-01-2003, 03:51 PM
stiffler is an unknown
I have an 04, and mine does the same thing, done it since I got it, and only have 1,000 miles, I checked all under the car for any thing that could be loose,
I think its normal, doesn't realy sound bad, just never heard anything like it from any other car that I have driven
stiffler is offline
post #5 of 12 Old 10-01-2003, 08:56 PM
Tut4u2's Avatar
Images: 11
Do mean a grinding sound or like an airplane sound? The airplane sound is normal, but the grinding sound is not. I have driven both 04 WRXs and STIs and there is no grinding sound, nor should there be any. But there will be like an airplane sound as the tranny deacclerates.
Che
Tut4u2 is offline
post #6 of 12 Old 10-01-2003, 11:05 PM Thread Starter
Kev
Kev is an unknown
I have both, the airplane sound is sweet. The grinding sound is embarrassing. Nothing as bad as gears grinding, but the exact sound of a heat shield rattling. This noise comes only at very low rpm's, after the airplane sound is gone. I think I'm taking another look, this doesn't seem normal. Thanks every body for you help
Kev is offline
post #7 of 12 Old 03-03-2006, 07:20 PM
stielinc is an unknown
I'm bring this thread back from the dead.....I'm experiencing the same 'heat shield' rattle that this thread addresses and mine too is only on decel while the clutch is engaged...any ideas?
stielinc is offline
post #8 of 12 Old 03-18-2006, 05:42 PM
Imprezzive is an unknown
Send a message via AIM to Imprezzive Send a message via Yahoo to Imprezzive
I have the same sound with my Rex and Ive had it since Ive owned it. just mine happens in 3rd gear. if I'm at 2500-3000 rpm and i let of the gas in gear it makes a rattly sound, only in 3rd though. it has to be something in the tranny because it dont happen when the clutch is into the floor and nothings in gear. i also get a slight pinging sounds under the front of the motor in 2nd gear ACCELERATING lightly between 1600-1700 rpms, someone explain that ????
Imprezzive is offline
post #9 of 12 Old 03-21-2006, 08:09 PM
i found a couple threads over on nasioc about this issue. It looks like people with the 02 model and those that have had a lighter flywheel installed share this complaint. Apparently the fix for the 02 models is for Subaru to install a heavier flywheel. Has something to do wiht gear chatter or something or other
stielinc is offline
post #10 of 12 Old 03-22-2006, 12:15 AM
sborderz is an unknown
Send a message via AIM to sborderz
Hmm, this airplane sound people are talking about, is that the sort of, whine that comes from the lower gears?
sborderz is offline
post #11 of 12 Old 03-22-2006, 12:58 AM
awd>fwd's Avatar
awd>fwd is an unknown
Yeah, its a slight whine. Never thought of it as an airplane sound but I guess so.
Brent
awd>fwd is offline
post #12 of 12 Old 03-22-2006, 02:17 AM
I'm glad to hear that's normal. I was beginning to wonder a little.
sborderz is offline
