-   -   2009 WRX Help Needed from Veterans (http://www.wrxtuners.com/forums/f72/2009-wrx-help-needed-veterans-50234/)
gart 06-12-2014 12:27 PM
Hi all,
I have a couple of mechanical questions and I think this is the best place to find people knowledgeable about the ins and outs of WRXs
I'm just about to buy a 2009 WRX.
It had its timing belt done at 30k miles and was wondering if that's unusual (or maybe a sign of some bigger troubles) and if I should replace the timing belt now at 100k when I do buy it.
Some further info is it failed the emissions test then passed the next day, not sure if that's unusual too or signs of something else.
Any insights would be greatly appreciated.
Thanks!
boo-key 06-12-2014 12:51 PM
549 Attachment(s)
Yes, a timing belt replaced at 30k is unusual. Did they not give you an explanation why? For safety sake I would still replace it at the recommended service interval. Better safe than sorry. As for the emissions, I don't know anything about that cause we don't have it here and don't want it!
Brockton 06-12-2014 01:47 PM
Emissions could be a lot of things, he may have had a cel for an 02 sensor or any number of things and just fixed it to pass.
The timing belt is pretty strange though. They usually aren't due till around 100k miles.
arcticscythe 06-12-2014 03:19 PM
[quote=gart;457370]Hi all,
Thanks![/quote]
The emissions is usually a sign that the previous owner modded his/her vehicle and in many cases the ref will either call them on it or in states where just the sniffer is used highflow cats or cat-less setups will fail the sniffer. Then people are forced to re-install their OEM equiptment for just the SMOG and test again. that or it may have been on a CEL that was resolved and re-tested.
The timing belt is a little odd but depending on the previous its not necessarily a red flag. I would swap it out for the 100k interval anyways but definitly ask why it was swapped so early. Could be an upgraded water pump or an over zealous mechanic looking for a quick buck.
