2008 WRX Stage 2- intermittent poor performance - Subaru WRX Forum
post #1 of 6 Old 01-29-2012, 12:38 AM Thread Starter
Doncostano is an unknown
I have a downpipe and a stage 2 flash. 48k miles
when im low on gas (1/8) the car performs extremely poorly, and when i quickly remove my foot from the throttle, the car bucks a lot harder then it normally would. started ~2000 miles ago. ive noticed that my temperature gauge spikes to extremely hot sometimes, but back to normal within mins, on half a tank or more its been better, but my car is definatly not accelerating the way it should be. i have a boost gauge, and it seems that when im makin max boost 18psi~ it accelerates perfect, where other times it struggles. but when i give it about 3/4, it felt better then WOT. Ive run my car real low on fuel for a bit of its life unfortunately. i think im losing fuel pressure. i know i have to modify the enclosure in my tank to put a walbro in if i have to replace the fuel pump. can i? could this be the problem? is it hard? maybe my fuel filter is clogged/ needs to be replaced. someone told me that on the 2008+ the filter doesnt get changed, i couldnt find specific information on it. the maitenance manual says every 60k, but i think the chart is for more then just the wrx, so may be wrong, despite it coming with my car. car has been runnin stage 2 strong on 18-20psi for 25-30k~ miles. maybe some injector cleaner. ive already paid enough in transmission/clutch over the cars lifetime and sick of dealing with garages, hoping i could take care of this problem myself. any advice? ask me anything
Doncostano is offline
post #2 of 6 Old 01-30-2012, 07:12 AM
It wouldn't hurt to switch the FP out to a walbro. You can do it yourself, takes about 2 hours. Check on scoobymods for the install. Here's a good link : Unabomber's Manifesto - Injector, Fuel Pump, and Fuel Rail FAQ - MySubie.com
FYI: You will need to remember to keep the tank on >1/4 tank if you use the walbro sock(filter).
Have you tried to clean the MAF yet ? Maybe a seafoam treatment ?
post #3 of 6 Old 01-30-2012, 02:15 PM
pimmeh's Avatar
pimmeh is an unknown
Just throwing this out there. i had a situation very close to yours and i suspected it was bad gas. mostly becuase it was immediately after a fill up at a pleace i never go to. regaredless it never "bucked" on me ever or ever over heated. After a reflash and some fresh 94oct she was roaring again. havent had the problem since then but if your running an AP a reflash might help plus you can look at your injector cycle duty if it's really high then it might be a good idea to drop in a walbro....
Good luck!
pimmeh is offline
post #4 of 6 Old 01-30-2012, 02:40 PM
I wouldn't think it's bad gas as it happens at 1/8th or lower (meaning it's happened more than one time).
What mods do you have on the car?
post #5 of 6 Old 01-30-2012, 03:12 PM Thread Starter
Invidia catless downpipe and an opensource XPT stage 2 tune
the cars been runnin strong up until lately. i havnt done any sort of maintenance other then oil changes. i really hope that its the pump or the filter cause ive spent enough on tranny repairs as it is.
post #6 of 6 Old 01-31-2012, 06:53 AM
Ok, almost sounds like fuel cut. Have you done any logs? And no other mods? 3port?
Several of the guys on here will take a look at the logs, i'm sure.
