2006 Wrx p0442 - Subaru WRX Forum
 1Likes
  • 1 Post By boo-key
post #1 of 9 Old 08-06-2013, 08:53 PM Thread Starter
06_hawk_eye's Avatar
06_hawk_eye is an unknown
2006 Wrx p0442
Well I've had this problem for while now. My car gets a p0442 it's a small evap leak detected. It only comes on when I'm on the highway for about 30 mins with cruise control set to 60mph+. I already replaced the gas cap. I can drive around town for a month but as soon as I get on the highway and set cruise control light comes on. I drove to ocean city Maryland from lancaster about 160 miles no light but I also didn't use the cruise control on the way back about 20 miles in I used the cruise control 10 miles later and light came on. Does anyone have any suggestions for this code.
Sent from AutoGuide.com App
06_hawk_eye is offline
post #2 of 9 Old 08-06-2013, 10:31 PM
P0442 Evaporative emission control system malfunction
Code list for your pleasure!
Are you still just stage 2?
post #3 of 9 Old 08-06-2013, 10:47 PM
boo-key's Avatar
There's a evap purge control solenoid. If your looking at the engine its on the left side behind the alternator . It is bolted to the front of the intake manifold. I would check it and make sure all the connections are good no broken or loose hoses. You may want to also take a look around your charcoal canister. Its a black box behind the (right?) rear wheel. Check connections on that as well. Im not sayin those are your problems but, they are in the evap system and easy to check.
turmic likes this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #4 of 9 Old 08-07-2013, 08:17 AM Thread Starter
Yeah still just stage 2.
post #5 of 9 Old 08-07-2013, 08:18 AM Thread Starter
Will be going up on the lift tonight for a couple minutes to see if I can find any loose or cracked hoses
post #6 of 9 Old 08-07-2013, 10:17 PM
check your gas cap too
post #7 of 9 Old 08-08-2013, 09:58 AM Thread Starter
Replaced the cap already
post #8 of 9 Old 08-08-2013, 11:32 PM
Did you check the black box underneath the right side rear? The evap box could have a loose hose or be messed up to a certain degree. Otherwise its a electrical gremlin in the system that doesn't like it when you use the cruise control. The purge solenoid could be bad too like Adair said...
post #9 of 9 Old 08-09-2013, 01:04 AM
Crap, missed that on your OP... sorry about that. Check the hoses like Kirt said..
