2006 wrx boost problem. Need fast help! - Subaru WRX Forum
post #1 of 2 Old 11-09-2010, 05:35 PM Thread Starter
Mr. Bojangles is an unknown
Ok i checked the previous boost threads and found some good things to check for but nobody was having the same problem as me. Yesterday and before i was getting around 24psi boost on a 2nd gear pull. I had a local shop do an oil change for me today (no time) as I'm leaving on a road trip (moving) tomorrow morning. Now, on the way home from the oil change I'm only getting 13 psi on a 2nd gear pull. Something is terribly wrong! Could a leak in a vaccum hose cause that much of a drop!?!?! please help!
Update...checked all vacuum lines and it's all good. But, during a high boost run i through a check engine light. P0244. Wastegate valve malfunction (high input). how do i fix that!?!?!
Ok I'm an idiot... searched p0244 and found my solution. just over boosted as it's 35 degrees outside.
Josh
2006 WRX-tr
1998 Nissan Silvia S-14
Mr. Bojangles is offline
post #2 of 2 Old 11-10-2010, 08:43 AM
Yeah they can overboost when it gets cold out, especially if you're in the "stage II" area. A 3-port may solve the issue if you don't have one, but you'll need to get a custom tune for it
