2004 WRX Code P0304 - Page 3 - Subaru WRX Forum
post #31 of 37 Old 12-27-2009, 05:26 PM Thread Starter
RUUP4IT101 is an unknown
So almost more than likely it is the cracked head or ring or something in the cylinder? Just curious about something though. Why would it be saying it was misfiring in one and three before that, if the four cylinder was cracked and now it isn't misfiring there after I replaced the spark plugs and the ones I took out look fine no corrosion or anything? This has just gotten me all confused.
RUUP4IT101 is offline
post #32 of 37 Old 12-27-2009, 05:32 PM
VD5505's Avatar
hard to tell, you really need to do that test that will tell us alot.
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #33 of 37 Old 12-27-2009, 05:35 PM Thread Starter
I appreciate your help. I'm going to go do the knock sensor test now and see if it may be that and do the compression test and leak down test tomorrow since everything here is closed on sundays. I hope it would be as easy as the knock sensor. I've been reading where guys have had similar problems and it be their knock sensor. Well two guys from another forum, but have run down all scenarios you know. As well take it tomorrow to do those test.
post #34 of 37 Old 12-27-2009, 05:41 PM
VD5505's Avatar
Alright man i wish you the best of luck!!
Brian
VD5505 is offline
post #35 of 37 Old 12-30-2009, 07:54 PM Thread Starter
Just to let you all know. I took my car to the dealership and at first they said the cause of everything was bad gas but then they said it wasn't that but my timing belt now. We shall see
post #36 of 37 Old 12-31-2009, 12:57 PM
VD5505's Avatar
why do all the dealerships say bad gas or timing belts my god, if it is your timing belt i would really do it yourself and save yourself A LOT of money.
Brian
VD5505 is offline
post #37 of 37 Old 01-05-2010, 12:47 PM Thread Starter
Well to update you all the final answer to my problems is it was a bad wastegate in my Turbo causing a vacuum leak. So in that case I'm just going to get turboxs stage 4 kit.
