2004 WRX Code P0304 - Page 2 - Subaru WRX Forum
post #16 of 37 Old 12-27-2009, 03:50 PM Thread Starter
RUUP4IT101 is an unknown
What do you mean its too late. Do you think the engine could have blown...? Ok so should I take the coil packs out while it is running or turn off the car and remove them one by one and restart the car?
RUUP4IT101 is offline
post #17 of 37 Old 12-27-2009, 03:55 PM
VD5505's Avatar
no just take the wire harness off each coil pack the black clips go in the back coil packs and the white clips are the two front coil packs.
VD5505 is offline
post #18 of 37 Old 12-27-2009, 03:58 PM Thread Starter
Where is the ECM fuse? I'm not sure where to find that one at.
post #19 of 37 Old 12-27-2009, 04:01 PM
VD5505's Avatar
shoot lol, i think its under the hood try that, if not its in the car behind that little ash tray deal on the drivers side or just take the fuel pump fuse out just any fuse so it will not let the car start.
VD5505 is offline
post #20 of 37 Old 12-27-2009, 04:04 PM Thread Starter
I appreciate your help man. I'm just dreading it being something so major. What do you think it could be please be honest so I know what I'm looking at to spend to fix it...
post #21 of 37 Old 12-27-2009, 04:09 PM
VD5505's Avatar
well from spending A LOT of time with Subaru's and the past 10 years of my life doing nothing but building, tuning, and racing i have seen alot ha, but really i believe you cracked a piston ring land, or a piston, or a cylinder wall, but really you need to get this compression test done, you can go to advance auto parts and buy one they are pretty cheap maybe they even rent them out. But after you do these tests let me know
VD5505 is offline
post #22 of 37 Old 12-27-2009, 04:24 PM Thread Starter
I greatly appreciate your help. I'm going to go pull the ECM fuse now and then pull the coil pack wires. I hope it doesn't cost an arm and a leg.
post #23 of 37 Old 12-27-2009, 04:32 PM
VD5505's Avatar
Good luck man, maybe you can have the money for a STI shortblock
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #24 of 37 Old 12-27-2009, 04:38 PM Thread Starter
I hardly have money to wipe my own well you know lol.
post #25 of 37 Old 12-27-2009, 04:46 PM
VD5505's Avatar
well maybe it will be something cheap, if your piston is cracked or something i have alot of spare parts laying around including 3 other EJ20 pistons
Brian
VD5505 is offline
post #26 of 37 Old 12-27-2009, 04:50 PM Thread Starter
I appreciate it... I just found a mechanics manual they use at the subaru dealerships for STi's. I'm actually doing your suggestion first because I know how the dealerships are. They just want your money pretty much.
post #27 of 37 Old 12-27-2009, 04:51 PM Thread Starter
post #28 of 37 Old 12-27-2009, 04:56 PM
VD5505's Avatar
just a quick note, if you have something to add instead of making two posts in a row (double post) just hit the edit button and add or whatever you want to do.
Brian
VD5505 is offline
post #29 of 37 Old 12-27-2009, 05:20 PM Thread Starter
Sorry about that. I'm not good with forum stuff. Anyways I did what you said and when I took out the ECM fuse the engine had spark but wouldn't turn over. As well when I went to take out the wire to the coil packs the CEL would flash, but when i went to put back in the number four the one that has been misfiring it smelled instantly like gas. What now? I was thinking about doing a knock sensor test just to make sure and look at the timing belt. What do you think you have more experience than I do.
post #30 of 37 Old 12-27-2009, 05:23 PM
VD5505's Avatar
compression test!!
Brian
VD5505 is offline
