2003 wagon hesitation - Page 2 - Subaru WRX Forum
post #16 of 20 Old 04-20-2012, 11:19 PM Thread Starter
cobra280z is an unknown
I've had the car for about 2.5 years. I don't have a boost gauge, so I'm not sure what my boost is. I'm certain that the injectors are all working at low flow anyway, since the car runs very smoothly until i get into boost and higher RPMs in 2nd and 3rd gear. I've read that being off by small amounts in fuel pressure can make a big difference, maybe this is causing the hesitation? I've also thought about the coils being bad, but again there's no way to check them reliably without switching them out for a good set (which I don't have access to).
cobra280z is offline
post #17 of 20 Old 04-21-2012, 08:38 AM
You need to find out what boost you are hitting.... In all gears really...
I don't think it's spark, but I could be wrong.
BUMP
post #18 of 20 Old 05-02-2012, 10:12 PM Thread Starter
Update
So, finally got a boost gauge and installed it this afternoon. Did a few runs this evening. As usual, first and second feel very strong at WOT. Saw ~11ish psi in first, about 13 in second. Third made about 13 as well at WOT, though it didn't feel as strong. There is no bucking in third at WOT. There is, however, considerable bucking/hesitation in second and third at partial throttle above about 3k rpms. The boost isn't jumping all over the place though. I guess that this hesitation at partial throttle is the next thing I need to address. Any ideas?
post #19 of 20 Old 05-03-2012, 05:52 AM
Try to clean out the injectors, worst case scenario is that you are doing routine maint.
You didn't do anything with the coils yet?
post #20 of 20 Old 06-29-2012, 01:09 AM Thread Starter
Finally figured it out- my car has a bad MAF, even though it drives normally 95% of the time. After switching with a friend, the car was perfect!
