Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 07-16-2009, 08:03 PM   #1 (permalink)
Reputation: jbowling88 is an unknown
2002 wrx with mods has misfire across the board
i have a 2002 wrx with crower 264 cams, ferrea endurance spring kit, brian crower vavles, a perrin bov, and short ram intake, accessport v1, cobb uppipe, borla shorty down pipe, ( still have 3rd cat) and an hks hi-power exhaust. i have misfires across the board.
p0301
p0302
p0303
p0304
the misfire is very very very slight. i also have a what i think is low idle ( about 500 rpm) the light doesn't flash usually comes on at idle and stays on solid ( not like a normal misfire) and when it comes on it's all for codes at once not just one.
i was wondering if anyone else has the same or similar set up or has herd of this problem and has a solution
any questions feel free to ask. thank you
Old 07-16-2009, 09:22 PM   #2 (permalink)
EJ Rex's Avatar
Car: 04 WRX
Club Region: Southeast
Reputation: EJ Rex is a helpful contributing member
Send a message via Yahoo to EJ Rex
What plugs, and what heat range are you running? Do you have an AFR gauge?
04 SRR WRX 370whp / 401wtq / EJ205
05 PBM GTO 440whp / 470wtq
http://www.youtube.com/user/EJRex
Old 07-16-2009, 10:20 PM   #3 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi is known to be trustworthy and helpful 03 CrazyTaxi is known to be trustworthy and helpful
What about lightweight flywheel or crank pulley?
Old 07-17-2009, 06:47 PM   #4 (permalink)
i have denso ik22 iridum v groove plugs ( one step colder from stock) and i don't have a a/f gauge but my scan tool is telling me lean. i'm leaning towards a MAF sensor as everything is pointing to that and i disconnected it and it stopped running lean so i have one on order from suby.
and no lightened anything.
Old 07-19-2009, 03:16 PM   #5 (permalink)
Some aftermarket intakes skew the MAF sensor calibration.That scan tool is actually useless as the ECU does not even use O2 sensor feedback in openloop.You would need a wideband AFR meter/sensor in order to correctly diagnose a AFR problem.The bugeyes were prone to missfires and I'm betting there is a possibility your cam timing is probably off.
Aarg matey!
ECU Pirated by RomRaider
