-20 psi? - Subaru WRX Forum
post #1 of 6 Old 03-10-2004, 09:53 PM Thread Starter
Narrus's Avatar
Narrus is an unknown
Send a message via Yahoo to Narrus
-20 psi?
Ok, so I used the oem boost gauge instructions to install my boost gauge. I went and ran the 1/4" line off the line going into the BOV (the 1/4" one) into a brass T, then from there behind the intercooler to the plug hole in the firewall. Ran it into the the boost gauge and started the car. The thing goes to 20 vacuum pressure and acts normal from there (range seemed to go from 20 to 5 or so on that side, reacting fairly consistantly). What'd I screw up?
Oh, and when you shut the car off the gauge would go back to zero. Took everything out and put it all back the way it was before. So far the car is ahead 3 to 0.
Narrus is offline
post #2 of 6 Old 03-11-2004, 03:32 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
At idle it should be 20 vac yes.
Che
Tut4u2 is offline
post #3 of 6 Old 03-11-2004, 06:08 PM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
20 vac at idle??? Seems a little off... 10psi off in fact...
Kobiyashi is offline
post #4 of 6 Old 03-11-2004, 07:24 PM
zoinks's Avatar
zoinks is an unknown
Send a message via AIM to zoinks
Mine runs 20 vac on idle when you first crank it but once it warms up it's between 15 & 20 vac. From what I've seen that's pretty normal with these cars.
zoinks is offline
post #5 of 6 Old 03-11-2004, 08:36 PM Thread Starter
Narrus's Avatar
Yeah, found that you need to test it under load. Duh. I'm a dumb a$$. Re-installed it tonight and it seems to settle around -15 once it's warm, and peaks about 12-13 psi at around 4500rpm in 3rd.
Narrus is offline
post #6 of 6 Old 03-11-2004, 11:34 PM
AZ-Scoob's Avatar
AZ-Scoob is an unknown
Send a message via MSN to AZ-Scoob
at least you asked for assistance or advice, and now you know!
.........car-0 you-1!!
[I]"Winners never quit, quitters never win, those that never win or quit are idiots."[/I]
AZ-Scoob is offline
